Problem Configuring 2621
Oct 01, 2007 6 Replies
Jump to replies (6)
Problem Configuring 2621 open original image
I have a somewhat vexing issue, the router is running 12.3(9)
I am configuring this to be a spare for an existing 2621 which is running 12.0(7). I enter all the configuration information and when done do a write to save it and to test it out do a power cycle and when it comes back up it starts a dialog
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
And the configuration I entered is gone. So I try the same again, but instead of write, copy running-config startup-config command, power cycle and same thing, the config is gone. Now,
Router# dir all Directory of nvram:/
25 -rw- 2824 startup-config 26 ---- 5 private-config 1 -rw- 0 ifIndex-table
29688 bytes total (25783 bytes free) Directory of system:/
10 drwx 0 its 2 dr-x 0 memory 1 -rw- 608 running-config 9 dr-x 0 vfiles
No space information available Directory of flash:8820 c2600-ik9o3s3-mz.123-9.bin
16252924 bytes total (74040 bytes free)
Now when I look at the files, running-config appears larger even though DIR says it is less than 1/4 the size. What happened to the config I entered? Is there a better wat to rransfer the config from one router to the other rather than a cut-and-paste approach.
Router#more nvram:startup-config ! ! Last configuration change at 22:03:07 UTC Mon Oct 1 2007 ! NVRAM config last updated at 22:03:25 UTC Mon Oct 1 2007 ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! enable secret 5 $1$dhgS$51AbmNnbK10TMv.4Farvw1 enable password xxxxxxxxxxx ! no aaa new-model ip subnet-zero no ip routing no ip cef ! !
Router#more system:running-config ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! ! no aaa new-model ip subnet-zero ip cef ! ! ! ip audit po max-events 100 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface FastEthernet0/0 no ip address shutdown duplex auto speed auto ! interface Serial0/0 no ip address shutdown ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! no ip http server no ip http secure-server ip classless ! ! ! ! ! ! ! ! line con 0 line aux 0 line vty 0 4 ! ! end
Router#
Router#show boot ^ % Invalid input detected at '^' marker.
Tried same on other router got the same
Tom,
Your router set to ignore config. Check your "config-register". Do "show version", and at the bottom of the screen look for Config Register value. If it's different from 0x2102, then change it to 0x2102:
conf t conf 0x2102 wr mem reboot
Good luck,
Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress)
------ Headset Adapters for Cisco IP Phones
Thanks, Mike. I could see al the output of the SHOW VERSION running remotely and talking through a Xyplex terminal server, and must be overrunning some buffers (another problem to solve) anyway I thought it wouldn't to reset the register, but no REBOOT command so issued RELOAD.
Did lose the config I had constructed. How do I copy the config from one router to another?
Tom
Thanks Mike, that appears to have solved my problem
Sorry about that, slipped into Catalyst mode for a second. It should have showed the boot and config-register stuff in show hardware (and show version as well I believe). Glad Mike helped you get this resolved...take care.
