PIX - Disable Ping / ICMP replies from outside interface
Jul 20, 2005 3 Replies
Jump to replies (3)
How do you disable ping replies to external clients on the outside interface while still allowing internal clients the ability to ping outbound and receive replies?
use "icmp " command: icmp deny any echo outside
I setup a quick lab to deminstrate this, please see below
end-user(e1/0)---(e1/0)local-as(e0/0)---(e0/0)remote-as (ISP)
I setup an access-list to allow incoming echo-replies destined for the local-as subnet.
access-list 101 permit icmp any echo-reply access-list 101 deny icmp any any access-list 101 permit ip any any
See below for examples:
end-user#ping 121.23.134.5
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 121.23.134.5, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 40/53/92 ms end-user#
remote-as#ping 178.101.23.105
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 178.101.23.105, timeout is 2 seconds: ...... Success rate is 0 percent (0/5) remote-as#ping 121.23.134.150
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 121.23.134.150, timeout is 2 seconds: ...... Success rate is 0 percent (0/5) remote-as#telnet 121.23.134.150 Trying 121.23.134.150 ... Open
User Access Verification
Password:
end-user#sh run Building configuration...
Current configuration : 728 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname end-user ! boot-start-marker boot-end-marker ! ! clock timezone PST 0 no aaa new-model ip subnet-zero no ip routing ! ! ! ! ! interface Ethernet0/0 no ip address no ip route-cache shutdown ! interface Ethernet1/0 ip address 178.101.23.105 255.255.255.0 no ip route-cache ! interface Serial2/0 no ip address no ip route-cache shutdown serial restart-delay 0 ! interface Serial3/0 no ip address no ip route-cache shutdown serial restart-delay 0 ! ! ip default-gateway 178.101.23.1 ip classless no ip http server ! ! ! ! ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4 ! end
end-user#
local-as#sh run Building configuration...
Current configuration : 883 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname local-as ! boot-start-marker boot-end-marker ! enable password cisco ! clock timezone PST 0 no aaa new-model ip subnet-zero ! ! ! ! ! interface Ethernet0/0 ip address 121.23.134.150 255.255.255.0 ip access-group 101 in no ip unreachables ! interface Ethernet1/0 ip address 178.101.23.1 255.255.255.0 ! interface Serial2/0 no ip address shutdown serial restart-delay 0 ! interface Serial3/0 no ip address shutdown serial restart-delay 0 ! ! ip classless ip route 0.0.0.0 0.0.0.0 121.23.134.5 no ip http server ! ! ! access-list 101 permit icmp any 178.101.23.0 0.0.0.255 echo-reply access-list 101 deny icmp any any access-list 101 permit ip any any ! ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4 password cisco login ! end
local-as#
remote-as#sh run Building configuration...
Current configuration : 690 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname remote-as ! boot-start-marker boot-end-marker ! enable password cisco ! clock timezone PST 0 no aaa new-model ip subnet-zero ! ! ! ! ! interface Ethernet0/0 ip address 121.23.134.5 255.255.255.0 ! interface Ethernet1/0 no ip address shutdown ! interface Serial2/0 no ip address shutdown serial restart-delay 0 ! interface Serial3/0 no ip address shutdown serial restart-delay 0 ! ! ip classless ip route 0.0.0.0 0.0.0.0 121.23.134.150 no ip http server ! ! ! ! ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4 password cisco login ! end
remote-as#
Hope this helps Anthony
My apologies I didn't see this post was for a PIX :)
