Cisco Switch/Router configuration help.
Nov 12, 2007 9 Replies
Jump to replies (9)
Hello,
I've done some cisco configurations in the past without much issue. Usually, between books and the internet, I can figure just about any of them out.. but this one is stumping me. Perhaps there's an IOS issue (like I have the wrong one), or perhaps it's pebkac.
I am trying to setup a sample network, or networks. I'm trying to configure a Cisco 26xx router, with one ethernet interface, with 2 sub interfaces on different networks (192.168.2.xx/24 and 192.168.248.xx/
24). On each of the subinterfaces I've added the router ip addresses.
On the switch (cisco 2950) I've put the port into trunk mode (same with the main interface on the router). i've added the ports to the appropriate vlans, but I'm getting no connectivity.
If anyone can please advise, and/or provide a link to further resources, I would appreciate it. Here are the devices and configs:
Cisco 2950:
eanut_sw1#sh ver Cisco Internetwork Operating System Software IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA4, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by cisco Systems, Inc. Compiled Wed 23-Mar-05 15:33 by yenanh Image text-base: 0x80010000, data-base: 0x80562000
ROM: Bootstrap program is C2950 boot loader
eanut_sw1 uptime is 22 minutes System returned to ROM by power-on System restarted at 07:43:26 CDT Mon Nov 12 2007 System image file is "flash:/c2950-i6q4l2-mz.121-22.EA4.bin"
cisco WS-C2950G-24-EI (RC32300) processor (revision L0) with 21039K bytes of memory. Processor board ID FOC0937Z6KN Last reset from system-reset Running Enhanced Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 00:15:63:73:1B:40 Motherboard assembly number: 73-7280-05 Power supply part number: 34-0965-01 Motherboard serial number: FOC09371F6S Power supply serial number: PHI0931C2MW Model revision number: L0 Motherboard revision number: A0 Model number: WS-C2950G-24-EI System serial number: FOC0937Z6KN Configuration register is 0xF
Cisco 2610:
#sh ver Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(10), RELEASE SOFTWARE (fc3) Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Tue 17-Aug-04 05:11 by kellythw Image text-base: 0x80008098, data-base: 0x819E9FE4
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
uptime is 54 minutes System returned to ROM by reload at 11:57:15 CST Tue Mar 2 1993 System image file is "flash:c2600-ik9o3s3-mz.123-10.bin"
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to snipped-for-privacy@cisco.com.
cisco 2610 (MPC860) processor (revision 0x202) with 61440K/4096K bytes of memory. Processor board ID JAD041007W7 (1350106988) M860 processor: part number 0, mask 49 Bridging software. X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Now onto the applicable configs:
2950 (the port Im plugging the switch into is fa0/1, so I stopped there):
Current configuration : 2055 bytes ! ! Last configuration change at 08:33:33 CDT Mon Nov 12 2007 ! version 12.1 no service pad service timestamps debug datetime localtime service timestamps log datetime localtime ! hostname eanut_sw1 ! clock timezone CDT -6 ip subnet-zero ! ! spanning-tree mode pvst no spanning-tree optimize bpdu transmission spanning-tree extend system-id ! ! ! ! interface FastEthernet0/1 switchport mode trunk !
Cisco 2510 config:
! interface Ethernet0/0 no ip address no ip unreachables no ip proxy-arp full-duplex no cdp enable ! interface Ethernet0/0.1 encapsulation dot1Q 1 native ip address 192.168.2.99 255.255.255.0 no cdp enable ! interface Ethernet0/0.2 encapsulation dot1Q 2 ip address 192.168.248.99 255.255.255.0 no cdp enable !
with this setup, I cannot ping any devices on either network, and the network cannot ping the .99 addresses assigned on the router. Please advise. Hopefully, I'm just missing something obvious.
Thank you,
Jim Surles
Have you checked the encapsulation type on the 2950? I see you have configured the trunk, but I am not sure of the default trunking encap on the 2950. May want ot make sure you have the same on both sides. Additionally, are you going to put your management interface on the
2950 in one of the vlans so you can test from switch to router before you test from node in switch to router? May help you...
i currently have the switch addressed as 192.168.2.10 (192.168.2.x is the currently implemented network), all of the ports in use use this network on the default vlan 1. I have tried setting the encapsulation specifically on the 2950, and it wouldn't work.. ie, the command wasn't there (switchport trunk encapsulation dot1q). From what Ive read the 2950 does not support ISL, only dot1q, so it does this by default.
Anything else to look into?
Interfaces up on both devices? Speed/duplex are hard coded correct? Paste a show int on both devices. Have you switch it back to an access port on the both sides and can ping then?
Do a show run and paste up the finding.
On Nov 12, 11:48 am, c0d3w12 wrote:
Yes, both interfaces are showing up/up
here is the full switch configuration:
my_sw1#sh run Building configuration...
Current configuration : 2055 bytes ! ! Last configuration change at 09:52:51 CDT Mon Nov 12 2007 ! version 12.1 no service pad service timestamps debug datetime localtime service timestamps log datetime localtime no service password-encryption ! hostname my_sw1 ! enable secret 5 $secretstuff ! clock timezone CDT -6 ip subnet-zero ! ! spanning-tree mode pvst no spanning-tree optimize bpdu transmission spanning-tree extend system-id ! ! ! ! interface FastEthernet0/1 switchport mode trunk ! interface FastEthernet0/2 shutdown ! interface FastEthernet0/3 shutdown ! interface FastEthernet0/4 shutdown ! interface FastEthernet0/5 shutdown ! interface FastEthernet0/6 shutdown ! interface FastEthernet0/7 shutdown ! interface FastEthernet0/8 shutdown ! interface FastEthernet0/9 shutdown ! interface FastEthernet0/10 shutdown ! interface FastEthernet0/11 shutdown ! interface FastEthernet0/12 shutdown ! interface FastEthernet0/13 description IP Phone ! interface FastEthernet0/14 shutdown ! interface FastEthernet0/15 description hydrogen - internet link bandwidth 6000 ! interface FastEthernet0/16 shutdown ! interface FastEthernet0/17 description calcium link ! interface FastEthernet0/18 shutdown ! interface FastEthernet0/19 description chlorine link ! interface FastEthernet0/20 description potassium link ! interface FastEthernet0/21 description 100 mbs to helium (back house) ! interface FastEthernet0/22 description Arsenic speed 100 ! interface FastEthernet0/23 shutdown speed 100 duplex full ! interface FastEthernet0/24 shutdown ! interface GigabitEthernet0/1 shutdown ! interface GigabitEthernet0/2 shutdown ! interface Vlan1 ip address 192.168.2.10 255.255.255.0 no ip route-cache ! ip default-gateway 192.168.2.1 ip http server snmp-server community public RO snmp-server location Garage Rack snmp-server contact Jim Surles ! line con 0 exec-timeout 0 0 line vty 0 4 password testing login line vty 5 15 password testing login ! ntp clock-period 17179777 ntp server 192.168.2.19 ! end
Here is the full router configuration:
my-rtr#sh run Building configuration...
Current configuration : 1281 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname my-rtr ! boot-start-marker boot system flash boot-end-marker ! logging buffered 4096 debugging enable secret 5 $secretstuff ! username jsurles password 7 083643410D clock timezone CST -6 clock summer-time CDT recurring aaa new-model ! ! aaa session-id common ip subnet-zero ip cef ! ! ip name-server 192.168.2.19 ! ip audit po max-events 100 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface Ethernet0/0 no ip address no ip unreachables no ip proxy-arp full-duplex no cdp enable ! interface Ethernet0/0.1 encapsulation dot1Q 1 native ip address 192.168.2.99 255.255.255.0 no cdp enable ! interface Ethernet0/0.2 encapsulation dot1Q 2 ip address 192.168.248.99 255.255.255.0 no cdp enable ! interface Serial0/0 shutdown ! ip default-gateway 192.168.2.1 no ip http server no ip http secure-server ip classless ! ! ! ! ! ! ! ! line con 0 line aux 0 line vty 0 4 password 7 15061206477E72 ! ntp clock-period 17208303 ntp server 192.168.2.19 ! end
Hopefully this will give people some insight, and hopefully I won't lose anymore hair than I already have. :P
I don't see an IP on interface FastEthernet0/1. Are the 192.x.x.x networks communicating?
I didn't put an IP on the fa 0/1 interface because it's "trunked", I didn't think I needed one. On the switch itself, there is an ip of
192.168.2.10, just not an independant one one the interface itself. All of the other 192.168.2.xx devices which are connected to the switch are communicating, but the 192.168.2.99 interface (eth 0/0.1 on the router) can not seem to see anything except for other addresses I might put on the router, but it's not passing anything through the switch.
Ethernet interfaces (10 MB) on Cisco (like 2610, 2611 and 2500 series) devices do not support dot1q or ISL, because the hardware chipsets they use do not support this functionality. It is a bug in the IOS software that allows you to even configure this. Another common IOS "bug" is setting duplex to full on these same device's 10 MB interfaces. You can set it, and a "show interface" will show the interface in full duplex mode, but again full duplex is not supported on the hardware on these 10MB interfaces and you will get errors.
"Thrill5" wrote in news:O6-dnSPJyKn2qKTanZ2dnUVZ snipped-for-privacy@comcast.com:
There was an older T train version where dot1q was supported, it did the tagging in SW. We used in on quite a few 2611s after memory upgrades. But seems like I recall an issue with untagged traffic (native vlan). You could try leaving vlan 1 the native, and move the ip from vlan 1 to a new vlan (vlan 3) so that the traffic gets tagged and see if that works.
c
