old c2900xl switch
Sep 09, 2006 5 Replies
Jump to replies (5)
old c2900xl switch open original image
I have an old C2900xl switch with ver 11.298.10SA6 installed. I just wanted to set the time and date on the switch. I searched and still can not get the right command line.. Can someone show the correct way to set the time and date on this switch
Thanks
If the switch is using IOS then try clock set
test#clock set 11:59:00 09 Sep 2006 test#sh clock
11:59:03.359 UTC Sat Sep 9 2006
Hi Gene,
set time
Use the set time command to change the time of day in the system clock.
set time [ day_of_week ] [ mm/dd/yy ] [ hh:mm:ss ]
Syntax Description
day_of_week (Optional) The day of the week.
mm/dd/yy (Optional) The month, day, and year.
hh:mm:ss (Optional) The current time in 24-hour format.
Default
This command has no default setting.
Command Mode
Privileged.
Example
The following example shows how to set the system clock to Wednesday, May 17, 1995 at
1:25:55 p.m.:
Console> (enable) set time wed 5/17/95 13:25:55 Wed Feb 22 1995, 13:25:55 Console> (enable)
Related Command
show time
Old Cisco Switch Technical Documentation:
Hope this helps.
Brad Reese BradReese.Com - Cisco Jobs
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Resumes
THANKS worked great... If it's not running IOS what would it be running???
Thansk for all the info. Got it set.....
