c2900XL-h-mz-112.8-SA4
Apr 21, 2009 5 Replies
Jump to replies (5)
How doess c2900XL-h-mz-112.8-SA4 differ from the enterprise version? Is it worth having enterprise version for small business?
Regards
David
The primary difference between Enterprise and Desktop version of IOS on that switch is VLAN trunking. You can seperate ports with VLANs on the Desktop code, but you can't setup any VLAN trunks off the switch. (the only other features are VTP and Dynamic VLAN/VMPS client in Enterprise).
Since I do alot of VLANs and trunking, it would matter to me. To you, perhaps not so much.
On Tue, 21 Apr 2009 16:17:46 +0000, Doug McIntyre wrote:
I traded the "A" version in for the "EN"... I think this was a good choice.
C2900XL Boot Loader (C2900-HBOOT-M) Version 11.2(8)SA4, RELEASE SOFTWARE (fc1) Compiled Mon 23-Nov-98 20:59 by paulines starting... Base ethernet MAC Address: 00:d0:bb:d5:04:00 Xmodem file system is available. Initializing Flash... flashfs[0]: 40 files, 3 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 3612672 flashfs[0]: Bytes used: 2998272 flashfs[0]: Bytes available: 614400 flashfs[0]: flashfs fsck took 85 seconds. ...done Initializing Flash. Boot Sector Filesystem (bs:) installed, fsid: 3 Parameter Block Filesystem (pb:) installed, fsid: 4 Loading "flash:c2900xl-c3h2s-mz.120-5.WC8.bin"...##################################################################################################################################################################################### File "flash:c2900xl-c3h2s-mz.120-5.WC8.bin" uncompressed and installed, entry point: 0x3000 executing... Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 Cisco Internetwork Operating System Software IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)WC8, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2003 by cisco Systems, Inc. Compiled Thu 19-Jun-03 13:09 by antonino Image text-base: 0x00003000, data-base: 0x0034E2F4
Initializing C2900XL flash... flashfs[1]: 40 files, 3 directories flashfs[1]: 0 orphaned files, 0 orphaned directories flashfs[1]: Total bytes: 3612672 flashfs[1]: Bytes used: 2998272 flashfs[1]: Bytes available: 614400 flashfs[1]: flashfs fsck took 7 seconds. flashfs[1]: Initialization complete. ...done Initializing C2900XL flash. C2900XL POST: System Board Test: Passed C2900XL POST: Daughter Card Test: Passed C2900XL POST: CPU Buffer Test: Passed C2900XL POST: CPU Notify RAM Test: Passed C2900XL POST: CPU Interface Test: Passed C2900XL POST: Testing Switch Core: Passed C2900XL POST: Testing Buffer Table: Passed C2900XL POST: Data Buffer Test: Passed C2900XL POST: Configuring Switch Parameters: Passed C2900XL POST: Ethernet Controller Test: Passed C2900XL POST: MII Test: Passed cisco WS-C2924C-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K bytes of memory. Processor board ID FAA0313M0N0, with hardware revision 0x01 Last reset from power-on Processor is running Enterprise Edition Software Cluster command switch capable Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s) 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 00:D0:BB:D5:04:00 Motherboard assembly number: 73-3381-04 Power supply part number: 34-0834-01 Motherboard serial number: FAA03039CAN Model revision number: A0 Model number: WS-C2924C-XL-EN System serial number: FAA0313M0N0
Press RETURN to get started!
C2900XL INIT: Complete
00:00:30: %SYS-5-CONFIG: Configured from NVRAM by console 00:00:32: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)WC8, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2003 by cisco Systems, Inc. Compiled Thu 19-Jun-03 13:09 by antonino
Swaped the "A" for an "EN"
Does anyone have a copy of swizzle "Cisco switch config" software?
BTW: c2900XL-hs-mz-112.8.12-SA6 should be the latest 4Meg Version for 2900 Series. You talking abount a 4Meg Switch?
bytes of memory.
