# of total CLI commands in 12.4(6)T4 for Cisco 3825
Mar 07, 2008 7 Replies
Jump to replies (7)
# of total CLI commands in 12.4(6)T4 for Cisco 3825 open original image
Doing some analysis for a 3rd party configuration tool and I need to know the total number of Cisco IOS commands found in the following image:
c3825-adventerprisek9-mz
Any estimates?
Anyone know for sure?
Do you need first level of commands? Count it by typing a "?" in a command prompt. Or, if you need all possible variants, then write a script to see all options, and type them with a "?".
Good luck,
Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress)
------ Headset Adapters for Cisco IP Phones
That won't get the hidden commands.
download the IOS command master index
and push it thru unix wc command
I don't think that will get the hidden commands either ;-)
It also would not be specific for 12.4(6)T4 for Cisco 3825
It will only provide an approximation.
The OP did not indicate why an exact number is requiredif it is for storage of the command then hopefully his application will be able to accomodate LOTS of growth in the number of IOS commands
The OP didn't say he needed an exact number. In fact, he specifically asked "Any estimates?".
boot the image and do a "show parser dump all" ?
