Setting E1 VWIC cards to ATM mode for Inverse multiplexing over ATM(IMA)
Aug 29, 2006 1 Replies
Setting E1 VWIC cards to ATM mode for Inverse multiplexing over ATM(IMA) open original image
Show version gives me this: __________________________ Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-IS-M), Version 12.1(22c), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Thu 01-Apr-04 18:05 by pwade Image text-base: 0x80008088, data-base: 0x80CDB1BC
ROM: System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
router01 uptime is 10 minutes System returned to ROM by power-on System image file is "flash:c2600-is-mz.121-22c.bin"
cisco 2610 (MPC860) processor (revision 0x00) with 30720K/10240K bytes of memory. Processor board ID J----------- (-----------------) M860 processor: part number 0, mask 49 Channelized E1, Version 1.0. Bridging software. X.25 software, Version 3.0.0. Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write) ________________________________________________
I have 2 VWIC E1 cards, one AIM-ATM card and an IP PLUS version of the IOS. I've been told the commands to get the E1 interfaces into ATM mode are the following:
Router#conf t Router(config)#controller E1(slot/port) es. 1/0 Router(config-controller)mode atm aim (slot)
But there seems to be no 'mode' command!! What am I doing wrong?
Thanks Ivan
Hi Ivan,
You may wish to investigate:
Set the E1 controller into ATM mode:
Hope this helps.
Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support
