Not able to ping my own interface !!!!
Apr 10, 2006 1 Replies
I have an M10 I am not able to ping my own interfaces can anybody help My config is oot# show interfaces fe-0/0/0 { unit 0 { family inet; } } ge-0/0/0 { unit 0 { family inet { address 40.5.255.253/16; } } } fe-0/0/1 { unit 0 { family inet; } } ge-0/0/1 { unit 0 { family inet { address 80.5.255.253/16; } } } fe-0/0/2 { unit 0 { family inet; } } lo0 { unit 0 { family inet { address 127.0.0.1/32; } } }
[edit] root#
Physical interface: ge-0/1/0, Enabled, Physical link is Up Interface index: 132, SNMP ifIndex: 30 Link-level type: Ethernet, MTU: 1514, Speed: 1000mbps, Loopback: Disabled, Source filtering: Disabled, Flow control: Enabled Device flags : Present Running Interface flags: SNMP-Traps 16384 Link flags : None CoS queues : 4 supported Current address: 00:14:f6:21:dc:1f, Hardware address:
00:14:f6:21:dc:1f Last flapped : 2006-04-10 00:17:38 UTC (00:09:58 ago) Input rate : 0 bps (0 pps) Output rate : 0 bps (0 pps) Active alarms : None Active defects : None
Physical interface: ge-1/0/0, Enabled, Physical link is Up Interface index: 133, SNMP ifIndex: 26 Link-level type: Ethernet, MTU: 1514, Speed: 1000mbps, Loopback: Disabled, Source filtering: Disabled, Flow control: Enabled Device flags : Present Running Interface flags: SNMP-Traps 16384 Link flags : None CoS queues : 4 supported Current address: 00:14:f6:21:dc:7e, Hardware address:
00:14:f6:21:dc:7e Last flapped : 2006-04-10 00:17:38 UTC (00:09:58 ago) Input rate : 0 bps (0 pps) Output rate : 0 bps (0 pps) Active alarms : None Active defects : None
root> ping 40.5.255.253 PING 40.5.255.253 (40.5.255.253): 56 data bytes ping: sendto: No route to host ping: sendto: No route to host ^C
--- 40.5.255.253 ping statistics ---
2 packets transmitted, 0 packets received, 100% packet loss
root> show con ^ 'con' is ambiguous. Possible completions: configuration Show current configuration connections Show circuit cross-connect connections root> show configuration | se ^ syntax error, expecting . root> show configuration | display set set version 7.4R1.7 set system syslog user * any emergency set system syslog file messages any notice set system syslog file messages authorization info set interfaces fe-0/0/0 unit 0 family inet set interfaces ge-0/0/0 unit 0 family inet address 40.5.255.253/16 set interfaces fe-0/0/1 unit 0 family inet set interfaces ge-0/0/1 unit 0 family inet address 80.5.255.253/16 set interfaces fe-0/0/2 unit 0 family inet set interfaces lo0 unit 0 family inet address 127.0.0.1/32 set routing-options static route 9.9.9.0/24 next-hop 4.4.4.5 set routing-options static route 72.5.0.0/16 next-hop 40.5.255.20 set routing-options static route 71.5.0.0/16 next-hop 40.5.255.10 set routing-options static route 75.5.0.0/16 next-hop 80.5.255.50
root>
Since this _is_ the Juniper group and all... ;)
So, you've shown us interfaces ge-0/1/0 and ge-1/0/0. It might be helpful to see what ge-0/0/0 looks like sine it's the once having issues.
-Wil
