Ping PIX inside interface through VPN
Jun 17, 2005 1 Replies
All,
I have problem trying to ping a pix. Situation is this:-
192.168.1.x - network
192.168.1.6 - pix 1 inside address pix 1 outside address internet pix 2 outside address
192.168.9.6 - pix 2 inside address
192.168.9.x - network
vpn tunnel set up through the interweb.
All services are up and working. All traffic passes back to head office , to use proxy servers, etc. Local hosts can ping the pix inside addresses. Remote hosts can ping eachother, but not the remote inside address. i.e, 192.168.1.10 can ping 192.168.9.10 (host), but not 192.168.9.6 (pix) pix 1 is running 6.1 pix 2 is running 6.0
I have tried:- icmp permit inside any icmp permit outside any access-list xx permit icmp any 192.168.9.0 255.255.255.0 access-group xx in interface outside
I've done debug icmp trace and it see's the icmp packets coming in, it just doesn't respond to them.
Am I missing something simple? Any ideas?
Best regards, Leigh
In article , Leigh Harrison wrote: :I have problem trying to ping a pix. Situation is this:-
:Remote hosts can ping eachother, but not the remote inside address.
:Am I missing something simple? Any ideas?
You can't do that with PIX 6.x, except through a tunnel which is defined as a management access tunnel. Note: such tunnels cannot be used to reach -through- the PIX, just -to- the PIX.
The general rule with PIX 6.x is that you can only ping the "closest" interface. Management tunnels are an exception to that.
