MS Remote Desktop Connection and Cisco VPN Client 4.0.3 D
Jan 04, 2006 2 Replies
I have a laptop that I would like to use MS Remote Desktop to connect to over hardwire Ethernet at the same time my VPN Client is using the WiFi adapter to connected to my office. I have no problem establishing the connection, but when I log into the VPN my Remote desktop session disconnects. Is there a way to configure the VPN client to allow this connection?
Thanks,
Peter Gonzalez snipped-for-privacy@gmail.com
You can tick the radio box that requests split tunneling, but unless the firewall administrator has enabled split tunneling, the client request will be ignored.
See bottom of thread...
My IT dept does not support or allow split tunneling. Why if I have a separate IP connection to this machine can't this "Just Work"?
Thanks
Peter
