MICA over PRI dial-out
Jul 25, 2005 2 Replies
MICA over PRI dial-out open original image
I would like to configure dial-out over MICA digital modems via a PRI ISDN adapter on a Cisco 3660 access router. I do not want to use DDR, but just the plain modem connection (e.g. via telnet to TCP port 2000 + line).
How can I tell the MICA modems to use a specific ISDN PRI interface (there are 2 interfaces in one of the slots)?
"isdn incoming-voice modem" does the job for incoming calls only, right?
Thank you very much!!
Dirk
line modem dialout controller
introduced on the 3600 platform in 12.2(10.2)T
Cheers,
Aaron
Hi Aaron,
thanks a lot!
Best regards Dirk
snipped-for-privacy@cisco.com wrote:
