dial in then telnet out
Mar 07, 2006 2 Replies
dial in then telnet out open original image
I'm trying to setup a dial in senario to see if cisco will do the job.
I have a 3600 with AUX port and ISDN BRI which I wish to be able to dial into via modems. Which are remote..
When connected via the aux I wish to telnet out to a host application listening on a TCP port.
Can this be done? Everything I read seems to point at reverse telnet but I don't think this is what I need.
any help would be apprecated.
----> DIAL IN ->>> aux [CISCO] ->>>>> TELNET OUT -> [HOST]
thanks Patt
What you need is async dial-in EXEC access.
You do not need reverse telnet.
see "Configuring a Modem on the AUX Port for EXEC Dialin Connectivity"
see "Modem-Router Connection Guide"
