Hi
anyone know if Cisco 7200 VXR NPE400 with ATM Card can support Interworking IP between ATM to ethernet vlan ?
Thanks mag
Hi thanks for your answer. Do you have tested directly ? If yes do you have a sample config with IOS version that you use ? Thanks mag
Read the full replyHi
Thanks mag
Yes it can.
Thanks mag
I have done this before using 155Mb/s ATM interfaces, but this was a long time when ATM was all the rage for backbones, and a few times when big frame-relay pipes from carriers were sometimes presented using ATM. It's a fairly simple config if you are doing this as a point-2-point. Cisco has many examples on their web site and ATM interface configurations are all basically the same for P2P. You configure an ATM PVC interface and then assign the IP address to it.
