Cisco 7200 Simulator
Oct 18, 2006 1 Replies
Please I need help in getting 7200 simulator to work. I followed the instructions from the site, still I could not get it to work. Can someone be so kind to show me the step-by-step instructions on what to do and what command to type. Thank you in advance for your help.
Help for Cisco 7200 simulator (dynamips-0.2.4) ============================================== Authors: Fabien Devaux, Christophe Fillot, MtvE
Emulated hardware
By default, a NPE-200 is emulated.
You can choose the NPE type with the "-t" option.
It is possible to select "npe-100", "npe-150", "npe-175", "npe-200", "npe-225", "npe-300" and "npe-400".
The "npe-g1" is not working.
Please note that you must use the C7200-IO-FE PA driver as IO card if you want a FastEthernet interface in slot 0.
For other slots, you must use the PA-FE-TX driver.
Command Line Options overview
-r : Set the virtual RAM size (default is 256 Mb)
-o : Set the virtual ROM size (default is 4 Mb)
-n : Set the NVRAM size (default is 128 Kb)
-l : Set logging file (default is pred_log0.txt)
-C : Import an IOS configuration file into NVRAM
-X : Do not use a file to simulate RAM (faster)
-R : Load an alternate ROM (default is embedded)
-S : Load a symbol file
-c : Set the configuration register (default is 0x2102)
-m : Set the MAC address of the chassis (IOS chooses default)
-k : Set the clock divisor (default is 2)
-T : Console is on TCP (default is on the terminal)
-A : AUX is on TCP (default is no AUX port)
-i : Instruction block trace, very slow
-j : Disable the JIT compiler, very slow
-t : Select NPE type
-M : Select Midplane ("std" or "vxr")
-p : Define a Port Adapter
-s : Bind a Network IO interface to a Port Adapter
-a : Virtual ATM switch configuration file
-f : Virtual Frame relay switch configuration file
-b : Virtual bridge configuration file
-e : Show network device list of the host machine
Command Line Options details
Specify the clock divider (integer) based on the host clock. Alter the value to match the CISCO clock with the real time. The command "show clock" at the IOS' CLI will help you set this value.
Format: slot:pa_driver:netio_type[:netio_parameters]
slot : the number of the physical slot (starts from 0)
pa_driver : the name of a port adapter driver in:
- C7200-IO-FE (FastEthernet, slot 0 only)
- PA-FE-TX (FastEthernet, slots 1 to 6)
- PA-4T+ (Serial, 4 ports)
- PA-8T (Serial, 8 ports)
- PA-A1 (ATM)
Format: slot:port:netio_type[:netio_parameters]
slot : the number of the physical slot (starts from 0) port : the port in the specified slot (starts from 0)
netio_type : host interface for communication
unix:: Use unix sockets for local communication. is created and represents the local NIC. is the file used by the other interface. (ex. "/tmp/local:/tmp/remote")
tap: Use a virtual ethernet device for communication. is the name of the tap device (ex. "tap0")
gen_eth: Use a real ethernet device for communication, using libpcap 0.9 or WinPcap. Works on Windows and Unix systems.
is the name of the Ethernet device (ex. "eth0")
The device list can be found using the "-e" option.
linux_eth: Use a real ethernet device for communication (Linux specific). is the name of the Ethernet device (ex. "eth0")
udp::: Use an UDP socket for connection between remote instances. is the port we listen to. is the host listening the port you want to connect to. is the port you want to connect to. (ex. "1000:somehost:2000" and "2000:otherhost:1000" on the other side)
tcp_cli:: Client side of a tcp connection. is the ip address of the server. is the port to connect to.
tcp_ser: Server side of a tcp connection. is the port to listen to.
null Dummy netio (used for testing/debugging), no parameters needed.
Escape commands
You can press ^] (Ctrl + ]) at any time, followed by one of these characters:
d : Show the device list r : Dump MIPS CPU registers t : Dump MIPS TLB entries m : Dump the latest memory accesses s : Suspend CPU emulation u : Resume CPU emulation q : Quit the emulator b : Dump the instruction block tree h : JIT hash table statistics c : Write IOS configuration to disk (ios_cfg.txt) j : Non-JIT mode statistics x : Experimentations (can crash the box!) ^]: Send ^]
If you press an unrecognized key, help will be shown.
Note: on Windows, it may be the "Ctrl + $" sequence.
Virtual Bridge
The virtual bridge is used to emulate a shared network between emulator
instances.
Any emulator instance can ast as a virtual bridge.
The configuration file (specified by the "-b" option) contains a list of NetIO descriptors, which the following syntax: netio_type[:netio_parameters]
Example:
# Connection to instance "I0" udp:10000:127.0.0.1:10001
# Connection to instance "I1" udp:10002:127.0.0.1:10003
# Connection to instance "I2" udp:10004:127.0.0.1:10005
The "I0" would be launched with the following parameters:
dynamips ios.bin -p 1:PA-FE-TX:udp:10001:127.0.0.1:10000
Virtual ATM switch
The virtual ATM switch fabric is used to emulate an ATM backbone between emulator instances.
The use of this virtual switch is not mandatory, you can directly connect emulator instances for point-to-point ATM connections.
Please note that only basic VP/VC switching is supported, there is no support for ILMI/QSAAL/... or other specific ATM protocols.
Any emulator instance can act as a virtual ATM switch.
Example of configuration file (specified by the "-a" option):
# Virtual Interface List IF:A0:udp:10001:127.0.0.1:10000 IF:A1:udp:10002:127.0.0.1:10003 IF:A2:udp:10004:127.0.0.1:10005
# VP connection between I0 and I1 VP:A0:10:A1:20 VP:A1:20:A0:10
# VP connection between I0 and I2 VP:A0:11:A2:30 VP:A2:30:A0:11
# VC connection between I1 and I2 VC:A1:5:2:A2:7:3 VC:A2:7:3:A1:5:2
In this example, we have 3 virtual interfaces, A0, A1 and A2.
The syntax for interface definition is similar to Port Adapters:
IF:interface_name:netio_type[:netio_parameters]
You can do VP switching or VC switching:
1) VP switching
syntax: VP:input_if:input_vpi:output_if:output_vpi
2) VC switching
syntax: VC:input_if:input_vpi:input_vci:output_if:output_vpi:output_vci
Testing the Virtual ATM switch with one dynamips instance
********************************************************* (Contribution of Mtv Europe)
Virtual ATM switch configuration file ("atm.cfg"):
IF:A0:udp:10003:127.0.0.1:10001 IF:A1:udp:10004:127.0.0.1:10002
# a0/vpi=1/vci=100 connects to a1/vpi=2/vci=200 VC:A0:1:100:A1:2:200
VC:A1:2:200:A0:1:100
Invoking dynamips:
./dynamips -p 1:PA-A1:udp:10001:127.0.0.1:10003 -p
2:PA-A1:udp:10002:127.0.0.1:10004 -a atm.cfg IOS.BIN
(note input ports of IOS interfaces are output ports of ATM switch interfaces, and vice versa).
IOS configuration:
ip cef ip vrf test rd 1:1 route-target both 1:1 int a1/0 no shut int a1/0.2 p ip addr 1.1.1.1 255.255.255.0 pvc 1/100 interface a2/0 no shut interface a2/0.2 p ip vrf forwarding test ip addr 1.1.1.2 255.255.255.0 pvc 2/200 !
# ping 1.1.1.2 !!!!!
Virtual Frame-Relay switch
The virtual Frame-Relay switch fabric is used to emulate a Frame-Relay backbone between emulator instances.
The use of this virtual switch is not mandatory, you can directly connect emulator instances with appropriate IOS configuration.
Any emulator instance can act as a virtual Frame-Relay switch.
There is only a basic implementation of the LMI protocol (ANSI Annex D), which is probably not conforming but works with Cisco IOS. Fortunately, Cisco IOS is able to detect automatically the LMI protocol.
Example of configuration file (specified by the "-f" option):
# Virtual Interface List IF:S0:udp:10001:127.0.0.1:10000 IF:S1:udp:10002:127.0.0.1:10003
# DLCI switching between S0 and S1 VC:S0:200:S1:100 VC:S1:100:S0:200
In this example, we have 2 virtual interfaces, S0 and S1.
DLCI switching syntax:
VC:input_if:input_dlci:output_if:output_dlci
In the example above, the switch is configured to switch packets received on interface S0 with DLCI 200 to interface S1 with DLCI 100, and vice-versa.
== EOF ==
Hope this helps.
