Intel Pro Wireless Cards cannot connect to Cisco 1200 series AP with new firmware
Jun 08, 2005 1 Replies
I am currently having a problem where i have just upgraded my cisco access points from 12.2(13)JA3 to a new version (I have tried all of the newest versions) but cannot get Intel Pro Wireless cards (Internal) to connect to the access point. I can see the access point, but cannot connect.
Whereas with Cisco wireless cards, I can connect with no dramas!
Does anyone else have this problem?
Current setup
Using WEP with PEAP. I also broadcast the SSID.
Is there any patches available for this problem??
Thanks, Mick
Mick snipped-for-privacy@hotmail.com schrieb:
Go to Security -> SSID Manager and ensure that at "Open Authentication" "with EAP (or with MAC and EAP)" is selected. A Cisco PCM352 or MPI350 card will authenticate if "Network EAP" is selected.
Not related to a specific IOS release.
The old Intel PRO2101B has an issue with broadcast key rotation, the newer ( Centrino(tm) ) has CCX and they should work. But I never use Intel WLAN since there is much better out there...
