Cisco AP rejecting non-Cisco clients
Aug 20, 2007 7 Replies
Jump to replies (7)
I recently upgraded the firmware (c1200-k9w7-tar.123-8.JA2) in my Cisco
1200 and 1100 APs. Unfortunately something very odd is now happening.
Cisco client cards (Windows), Xyxel USB (Windows), an Intel ProWireless
3945 (Linux), a wireless PDA and an Asus wireless bridge all connect fine.
However, any of the ten Orinoco Gold cards and an Intel ProWireless 2100 simply do not even see the SSID. It is like there is no wireless signal that they can see.
I have turned off all security and numerous times been through making sure all the Cisco extensions are disabled, min rate is set to 1Mb etc. - but these older cards just will not even see the wireless signal. There is nothing in the firmware release notes which is relevant either.
I have Netstumbler running on the Intel 2100 card and it has picked up every wireless network in the neighbourhood but cannot see the Cisco 1200 that is sitting underneath it!
I have a Chinese no-brand AP which everything can see fine. It seems the recent Cisco firmwares have added something to make them incompatible.
Anyone have any ideas or heard anything on these lines?
Cheers NK
As a follow up to this, I just managed to find an old download of the Cisco IOS from last year - c1200-k9w7-tar.123-7.JA1.tar - and have downgraded the AP1200 to it. Now everything works fine again.
Clearly there is something incompatible in the latest Cisco firmwares and you can't get the old firmwares from their download area.
If anyone needs the old firmware then let me know.
Cheers NK
~ On Mon, 20 Aug 2007 18:10:16 +0000, Noel wrote: ~ ~ > Hi, ~ > ~ > I recently upgraded the firmware (c1200-k9w7-tar.123-8.JA2) in my Cisco ~ > 1200 and 1100 APs. Unfortunately something very odd is now happening. ~ ~ As a follow up to this, I just managed to find an old download of the ~ Cisco IOS from last year - c1200-k9w7-tar.123-7.JA1.tar - and have ~ downgraded the AP1200 to it. Now everything works fine again. ~ ~ Clearly there is something incompatible in the latest Cisco firmwares and ~ you can't get the old firmwares from their download area. ~ ~ If anyone needs the old firmware then let me know. ~ ~ Cheers ~ NK
Hm. We know of a compatibility problem between Broadcom clients and aIOS
12.3(8)JA and above (CSCsf03190), but I'm not aware of one like this with the Intel 2100s or the Orinoco Gold (Agere Hermes?) adapters. It would be interesting to find out what the cause of this is.
As far as getting older 12.3(7)JA based IOS - that is available for download from www (need to register for a CCO account if you don't have one - a guest level account will work.) I would recommend 12.3(7)JA5 which has security fixes that are missing from JA1.
Regards,
Aaron
Yes - thanks Aaron that firmware works OK too.
I am very pleased to hear that I am not alone in this! Really strange the way the wireless signal is completely cloaked from these other devices.
Cheers NK
All going well until I tried to load older firmware on the AP1100. This is the oldest I can download from Cisco and it won't recognise my other cards:
c1100-k9w7-tar.123-4.JA2.tar
So a little stuffed really. Does anyone know where I can get older firmware for AP1100s?
Cheers NK
~ >> a guest level account will work.) I would recommend 12.3(7)JA5 which has ~ >> security fixes that are missing from JA1. ~ > ~ > Yes - thanks Aaron that firmware works OK too. ~ ~ All going well until I tried to load older firmware on the AP1100. This is ~ the oldest I can download from Cisco and it won't recognise my other cards: ~ ~ c1100-k9w7-tar.123-4.JA2.tar ~ ~ So a little stuffed really. Does anyone know where I can get older ~ firmware for AP1100s? ~ ~ Cheers ~ NK
If you really NEED IOS that's older than what we have on CCO, then you'd need to open a TAC case and get it posted for you. (The older code has security flaws that preclude us from making it generally available.)
If you're looking for good old low-featured IOS for the AP1100, 12.2(15)XR2 was pretty solid. Aaron
Thanks Aaron. I am asking the tech guys at my supplier if they have any older firmware available.
Cheers NK
Intel and Cisco have had some interoperability troubles latetly. Be glad you're not running LWAPP/440x Controller Based wireless.
Make sure you're running 11.1.1.0 of the Intel client. (I think that one supports the 2100)
