HWIC-4ESW
Jan 05, 2007 6 Replies
Jump to replies (6)
They are L2 ports, that can be trunked back into the router. They aren't L3 ports.
so is there any other way I can increase number of L3 ports in 2800 series router? I need 5 L3 phisicaly separated ports and not trunked virtual interfaces
VLAN tagging on the router, whereas one or more ports on the switch are represented on the router. can have every port in a separate VLAN on the router. However be aware are doing L# in software on the router at that point no hardware like a true L# switch and there is a bandwidth limit from the L@ switch HWIC card to the router, although is higher than the network modules can not remember how much, I am thinking 800mps combined full duplex ?
I agree that this is not clearly documented. We bought some 16 port "L2" cards (NM-16ESW) and I can absolutely confirm that they can be configured as either L3 interfaces OR configured as L2 in a VLAN and have SVIs (e.g int vlan 22) configured for routing. Take you pick.
We used both.
I expect that the one that you are proposing is similar. I asked our supplier to confirm. We are a low level Cisco partner so that was our Distributor.
Within the same VLAN you get hardware L2 switching, and within VLANs you get a software router is my understanding (by guesswork).
The configuration is just like a 6500 or 4500 or 3750 or 3560. No weird twiddly bits, just create VLANs, SVIs, or use pure L3 interfaces.
I have the idea that the 32 port card (36?) may have L3 hardware.
Cisco has just announced the HWIC-1FE and HWIC-2FE cards. They are 1-port and 2-port FastEthernet interfaces respectively, that are full L3 interfaces. A 2811 will support up to two HWIC-1FE cards (the HWIC-2FE is not supported on the 2800 series). The cards are expected to be available at the end of January.
Scott
thanks guys, you helped
