CF card compatibility with C6500/Sup720
Jan 05, 2007 0 Replies
I wanna use CF-cards not certified by Cisco, because it is very cheap than Cisco's. I've tested some CF-cards, but I found some CFs are not compatible w/ Sup720, for instance, transcend 80x 1G(TS1GCF80). (How to test: just insert CF into slot and try to format it.)
Is there anybody who has tried to test compatibility w/ 'Sandisk ExtremeIII' CF-card for C6500/Sup720? Or any compatibility-proved CF cards recommendation would be welcomed!
