Trouble with 1841 and 4ESW Switch
Jun 06, 2007 9 Replies
Jump to replies (9)
Hi
I have a 1841 router with 4 port Switch module (4ESW). I have configured a trunk on fa0/0 with the appropriate sub-interfaces. I know this trunk is working correctly as I have connected it to an external 2950 and been able to create a router-on-a-stick setup and ping the sub-interfaces in the 1841 from access ports on the 2950.
I want to be able to essentially achieve the exact same thing though using the built in 4ESW module. I want each of the four switchports on this module to be able to me access ports for four different VLANS all with sub-interfaces configured on the fa0/0 interface and then route between each other on the switch module. I would also like to span these same VLANs across the trunk between fa0/0 and the external 2950 allowing each layer 2 VLAN to be accessible via access ports on the
4ESW and the external switch with all routing occuring via the trunk/ sub-interfaces on fa0/0 on the 1841.
I cannot however even get devices connected to the 4ESW module to ping the sub-interfaces on the fa0/0 interface on the 1841 so there is obviously something wrong. Can anyone help with this. Below is the relevant elements of the 1841 and 2950 configurations.
Thanks in advance
1841
interface FastEthernet0/0 no ip address duplex auto speed auto description Link to 2950 fa0/1 ! interface FastEthernet0/0.101 encapsulation dot1Q 101 ip address 10.100.101.1 255.255.255.0 ! interface FastEthernet0/0.102 encapsulation dot1Q 102 ip address 10.100.102.1 255.255.255.0 ! interface FastEthernet0/0.103 encapsulation dot1Q 103 ip address 10.100.103.1 255.255.255.0 ! ! interface FastEthernet0/0/0 switchport access vlan 101 ! interface FastEthernet0/0/1 switchport access vlan 101 ! interface FastEthernet0/0/2 switchport access vlan 102 ! interface FastEthernet0/0/3 switchport access vlan 103 ! VLAN ISL Id: 101 Name: 101 Media Type: Ethernet VLAN 802.10 Id: 100101 State: Operational MTU: 1500
VLAN ISL Id: 102 Name: 102 Media Type: Ethernet VLAN 802.10 Id: 100102 State: Operational MTU: 1500
VLAN ISL Id: 103 Name: 103 Media Type: Ethernet VLAN 802.10 Id: 100103 State: Operational MTU: 1500
Cisco 2950
! interface FastEthernet0/1 switchport mode trunk description Link to 1841 fa0/0 !
VeeDub a écrit :
You need to configure bridge-groups between Fa0/0.101, Fa0/0/0 and Fa0/0/1 (for VLAN 101), between Fa0/0.102 and Fa0/0/2 (for VLAN 102) and between Fa0/0.103 and Fa0/0/3 (for VLAN 103).
Thanks for your response. I have looked for a guide to setting up bridge groups but cannot find anything specific. Can anyone povide a link to a good doco?
A couple of things here
  1. Are you using a Crossover cable? Since you're going from switch to switch, instead of router to switch, you will need a Crossover cable.
  2. Generally, if you have a trunk port on 1 side, you need a trunk port on the other side. You've hard coded your switchports on the
1841 to be access ports, and your 2950 port to be a trunk port. Given that one side will be sending dot1q tags and the other side won't be able to read them, this will not likely work very well
What I would suggest is the following:
On the 1841:
interface range fa0/0/0 - 3 switchport mode trunk switchport trunk encapsulation dot1q switchport trunk allowed vlan none switchport trunk allowed vlan add 101,102,103
On the other side, these VLANs should be configured to match, so do the following on the 2950
Assuming your VLANs aren't yet configured on the 2950:
conf t
vlan 101 exit vlan 102 exit vlan 103 exit
int f0/1 switchport trunk encap dot1q switchport mode trunk switchport trunk allowed vlan none switchport trunk allowed vlan 101,102,103
If you make sure to use a Crossover cable, that should work.
It should be noted that you will have to configure 4 ports in total on the 2950 to connect to 4 ports on the switch card if you want bandwidth over 100 mbps.
Hope that helps
Thanks Mike for your input,
I am actually using the router port though to connect to the external switch hence I do not need a cross-over cable. The trunk to the external switch is working absolutely fine as I can access and route between the different access ports assigned to the vlans on the 2950. The issue is that I want to do the same with the 4-ESW. However I need to bind the different switch ports (fa0/0/0-fa0/0/3) to the same vlans the sub-interfaces on fa0/0 and this is the issue.
Essentially, I want the following Layer 2 VLANs on the 1841 and the listed interfaces members of these VLANs
VLAN 101 fa0/0.101, fa0/0/0, fa0/0/1 VLAN 102 fa0/0.102, fa0/0/2 VLAN 103 fa0/0.103, fa0/0/3
I then want to be able to route betwen these VLANs using the L3 interfaces on each VLAN (fa0/0.101, fa0/0.102, fa0/0.103) for both the ports on the 4ESW and on the external 2950. As I mentioned, I am routing fine on the 2950 as this is straight forward. It is the routing between the 4ESW ports which is the issue. I also dont think what you are suggesting about configuring a trunk on the 4ESW ports will work as they are just Layer 2 interfaces, not Layer 3.
If you can assist withe creating he bridge groups to be able to put the 4ESW switchports on the same VLANs as the appropriate sub- interfaces on fa0/0 i would be appreciative.
Thanks
How long ago did you purchase this 1841? You probably have support on it. Call the TAC and they will help your or pretty much do it for you.
It was bought second hand, so I have no support for it.
Thanks
Good day
If I have this right, you have 2 objectives with this test that you're doing.
  1. You want to create a trunked connection between the 1st 10/100 fixed router port on the Cisco 1841 to a trunk port on the Cisco
2950. You have thus configured 3 sub-interfaces on the 1841 for the Fa0/0 port, each representing 1 VLAN, and you have configured the trunk port on the switch to carry the 3 VLANs to the Cisco router
  1. You want to create 3 VLANs on the 1841 for the 4 port switch, and relate 1 VLAN per port, all of whom will be configured in access mode
If you want to do this, you will still need to create 3 layer 3 VLAN virtual interfaces on the router. The fact that you have 3 trunked sub-interface ports does not mean that the layer 3 VLAN interfaces have yet been created. Here's what I suggest you add to the configuration:
interface vlan 101 ip address 10.100.101.2 255.255.255.0
interface vlan 102 ip address 10.100.102.2 255.255.255.0
interface vlan 103 ip address 10.100.103.2 255.255.255.0
What you could also do, in order to simplify everything is simply plug the trunk port on the 2950 into a trunk port on the hwic-4esw and carry the 3 vlans across.
To be honest, I've never tried doing this before. I do not, however, as mentioned, believe that the VLANs will carry over as layer 3 VLAN interfaces for the switchports, which are a separate module on the router, if you create sub-interfaces. The sub-interfaces will treat the VLANs as local to that connection, I believe
If anyone has any ideas on this, I wouldn't mind hearing them, as I'm not absolutely positive on what I'm saying here.
However, please give it a shot with what I suggested, as I suspect that should work
< snipped >
! I tink you will need this:- [maybe:-)]
! Clearly you may choose briigde group 101, 102, 103 ! but I though it woud be clearer to avoid that in the example.
! UNTESTED
bridge irb
bridge 1 protocol ieee bridge 1 route ip
bridge 2 protocol ieee bridge 2 route ip
bridge 3 protocol ieee bridge 3 route ip
interface FastEthernet0/0 no ip address duplex auto speed auto description Link to 2950 fa0/1 ! interface FastEthernet0/0.101 encapsulation dot1Q 101 bridge-group 1 ! interface FastEthernet0/0.102 encapsulation dot1Q 102 bridge-group 2 ! interface FastEthernet0/0.103 encapsulation dot1Q 103 bridge-group 3 ! ! interface FastEthernet0/0/0 switchport access vlan 101 ! interface FastEthernet0/0/1 switchport access vlan 101 ! interface FastEthernet0/0/2 switchport access vlan 102 ! interface FastEthernet0/0/3 switchport access vlan 103
int bvi1 ip address 10.100.101.1 255.255.255.0
int bvi2 ip address 10.100.102.1 255.255.255.0 int bvi3 ip address 10.100.103.1 255.255.255.0
! various "no shuts" if required
There may be a way to have the IP addresses on the .xxx sub interfaces instead but I can't get that picture right now.
On review, I don't think that is any good now. Sorry.
