How to check clock sync Serial Speed
Oct 17, 2005 4 Replies
Martin Kiefer
skrev i en meddelelse news: A T1 line runs at 1544kbit. not 2Mbit. Consult you ISP if your speed is wrong.
I've a router 1721 connected via WIC 1T to a serial cable (v35) that goes to the modem dce.
I've bought a 2 mbps contract for this serial line, but i'm in doubt if it configured to a lower interface speed ( 1.5 mbps )
Infact, "show interfaces serial 0" says
------------------------------------------------------ Serial0 is up, line protocol is up Hardware is PowerQUICC Serial MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 195/255, rxload 26/255 Encapsulation FRAME-RELAY IETF, loopback not set
It says the bandwidth is 1544kbit but should be 2048kbit
Is it possible to know how the physical serial interface is really configured ( if i'm not wrong it should be set to 2.000.000 clock speed ) and what clock frequency it receives?
thanks you much
skrev i en meddelelse news: snipped-for-privacy@g43g2000cwa.googlegroups.com...
This is just typed in to the router and bears NO relationship to the clock speed on the line. If nothing is type in there is a default setting that is used.
The value is used for the xx/255 dislpay and for some dynamic routing protocols. EIGRP and maybe IGRP (not been around this long enough?).
On some platforms - but not all
sh controllers s 0
displays the actual clock speed as detected on the line.
Normally you do not need configure clocking, the service provider does that. It is CRITICAL that there is only one clock for the whole circuit.
Ok, can the clock speed provided by the attached dce be esitmated reading the register stuff provided issuing "show controllers serial 0 " ?
I'm in doubt if the line is really a E1 or if it is configured as T1.
I include mine, thanks for any clarification about that.
Is there a guide for interpreting these register data?
Interface Serial0 Hardware is PowerQUICC MPC860 DTE V.35 TX and RX clocks detected. idb at 0x80C11658, driver data structure at 0x80C1915C SCC Registers: General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8 Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06 Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E Interrupt Registers: Config [CICR]=0x00365F80, Pending [CIPR]=0x00008000 Mask [CIMR]=0x40204000, In-srv [CISR]=0x00000000 Command register [CR]=0x600 Port A [PADIR]=0x0000, [PAPAR]=0x0903 [PAODR]=0x0000, [PADAT]=0xF6FF Port B [PBDIR]=0x0180F, [PBPAR]=0x0E00E [PBODR]=0x00000, [PBDAT]=0x3077C Port C [PCDIR]=0x000, [PCPAR]=0x000 [PCSO]=0x020, [PCDAT]=0xFCE, [PCINT]=0x000 Receive Ring rmd(FF002230): status 9000 length 3A address 1E34144 rmd(FF002238): status 9000 length 2E address 1E39C44 rmd(FF002240): status 9000 length 2E address 1E35B44 rmd(FF002248): status 9000 length 2E address 1E32744 rmd(FF002250): status 9000 length 2E address 1E3A2C4 rmd(FF002258): status 9000 length 2E address 1E354C4 rmd(FF002260): status 9000 length 35 address 1E3A944 rmd(FF002268): status 9000 length 23E address 1E3C9C4 rmd(FF002270): status 9000 length 3B address 1E3D044 rmd(FF002278): status 9000 length 23E address 1E32DC4 rmd(FF002280): status 9000 length 2E address 1E33AC4 rmd(FF002288): status 9000 length 3B address 1E3C344 rmd(FF002290): status 9000 length 3E address 1E36EC4 rmd(FF002298): status 9000 length 35 address 1E33444 rmd(FF0022A0): status 9000 length 23D address 1E361C4 rmd(FF0022A8): status B000 length 2E address 1E37544 Transmit Ring tmd(FF0022B0): status 5C00 length 590 address 1E299CA tmd(FF0022B8): status 5C00 length 223 address 1E2738A tmd(FF0022C0): status 5C00 length 298 address 1E04F4A tmd(FF0022C8): status 5C00 length 2C address 1E0290A tmd(FF0022D0): status 5C00 length 590 address 1DE712A tmd(FF0022D8): status 5C00 length 1F3 address 1DFBCAA tmd(FF0022E0): status 5C00 length 2C address 1E0AEEA tmd(FF0022E8): status 5C00 length 61 address 1E40D14 tmd(FF0022F0): status 5C00 length 590 address 1DF1D4A tmd(FF0022F8): status 5C00 length 171 address 1E2C66A tmd(FF002300): status 5C00 length 590 address 1E0428A tmd(FF002308): status 5C00 length 116 address 1DEDD8A tmd(FF002310): status 5C00 length 61 address 1E2ACEA tmd(FF002318): status 5C00 length 61 address 1E40D14 tmd(FF002320): status 5C00 length 590 address 1DEF0AA tmd(FF002328): status 7C00 length F8 address 1E2B9AA
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0xFF003C00) Rx BD Base [RBASE]=0x2230, Fn Code [RFCR]=0x18 Tx BD Base [TBASE]=0x22B0, Fn Code [TFCR]=0x18 Max Rx Buff Len [MRBLR]=1548 Rx State [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x2260 Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x22C8
SCC HDLC PARAMETER RAM (at 0xFF003C38) CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8 Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0 Nonmatch Addr Cntr [NMARC]=0 Retry Count [RETRC]=0 Max Frame Length [MFLR]=1608 Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=36464 User-defined Address 0000/0000/0000/0000 User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
1 input aborts on receiving flag sequence 0 throttles, 0 enables 0 overruns 0 transmitter underruns 0 transmitter CTS losts
thank you much
Not as far as I know. when I have seen the clock rate displayed it has been pretty clear and IIRC near the top. I know of no magic decodes.
Again not as far as I know. You could always ask TAC, however I guess they would be pretty unimpressed.
Most of it appears to be about the location of memory buffers and the like.
If you really really need to know you will have to get a suitable network analyser or an oscilloscope.
