hi all..
i have implemented qos for telnet traffic i.e. telent traffic use 32 kbps of guaranteed bandwith...
i want to know how can i check this implementation...
You didn't specified whether you implemented QoS on Cisco router or switch, so I will assume that this is about router: Bring the egress interface's load to it's max (or up to the traffic shaping value if any configured) and then execute IP SLA monitor probe... After that…
Read the full replyhi all..
Bring the egress interface's load to it's max (or up to the traffic shaping value if any configured) and then execute IP SLA monitor probe... After that, remove QoS policy-map from that interface and then load the link again and measure parameters using Cisco IP SLA, so that you can simply compare IP SLA results you get with and without QoS.
For more info about Cisco IP SLA, please visit:
B.R. Igor
Just use iperf. It's free and runs on Windows and Unix machines. Use the -p option to run it on port 23 to simulate telnet traffic.
