How to check equipment
Jul 20, 2005 1 Replies
KB
Plug 'em together ! Get yourself a back to back DTE DCE cable for the serial interfaces on the 2501's. In the meantime, plug the ethernet interfaces into the 2950's and do a "show interface" and see if the ethernet interfaces come up. You may need to do a "no shut" if they have…
Just got my (2) 2501s and (2) 2950s. What should I do to check to make sure everything is working? I can log into all devices fine, and everything seems to load fine. The 2501s both have 16mb main memory and 16mb system flash. One has
11.2, the other 11.0. The 2950s both have 12.1. Thanks!
2501's. In the meantime, plug the ethernet interfaces into the 2950's and do a "show interface" and see if the ethernet interfaces come up. You may need to do a "no shut" if they have been disabled.
