help needed Cisco 1721
Feb 12, 2006 3 Replies
Jump to replies (3)
I have a cisco 1721 router which we connect to corporate office with serial interface with a leased line having a VPN tunnel now we are moving to frame relay which is new to me, what are the configurations changes i have to do to enable it into frame relay I am attaching the samle configuration with the leased line.
Thanks in advance
interface Tunnel1
bandwidth 128 ip address x x x x. o ip redirects ip mtu 1440 ip nhrp authentication ip nhrp map multicast dynamic ip nhrp map xxxx xxxx ip nhrp map multicast xxxxx ip nhrp network-id 1 ip nhrp holdtime 300 ip nhrp nhs xxxx
ip ospf network broadcast no ip mroute-cache delay 2000 tunnel mode gre multipoint tunnel key 10204
! interface Loopback1 description [Router Loopback] ip address x x x x x x x x ! interface FastEthernet0 description [Local LAN] ip address x x x x x x x x
speed auto ! interface Serial0 bandwidth 128 ip address a b c d . no ip redirects no ip unreachables no ip proxy-arp !
It looks like you are using DMVPN currently
Will the new frame-relay circuit be between your remote site and tyour ISP ISP or between your remote site and your corporate office?
Hi
Thanks for the reply
Its betwen remote site and the corporate office.
Regrads
oops sorry for the mistake its between remote site and isp
Thanks
