Cisco 1721 WIC installation
Feb 13, 2007 0 Replies
We have 1721 cisco router, we will order WIC-1NET and WIC-4ESW install on two WIC slot. I want config WIC-1NET connect to ISP, Local LAN port connect to internal private Network. , another WIC-4ESW setup as DMZ, I will program each port connect to different server. I want not sure the WIC-4ESW is possible prgram each port function. Also I want using config maker setup this sturctute is OK. pls advice.
Thanks ITITIT
