Help! - default password used by CRWS?
Sep 12, 2005 2 Replies
www.BradReese.Com
Hi Toby, Cisco 800 Series Routers, Field Notice: Extra Usernames and Passwords in Config after Using CRWS. The CRWS telnet usernames/passwords are removed by issuing the command no username as shown in this example: Router#configure terminal Enter configuration commands, one…
Help! - default password used by CRWS? open original image
Need some help rather badly here :(
I've used the CRWS to reset my old 806 back to "factory" defaults but what on earth is the password it uses?
It's created a "Cisco" username on the thing but I can't seem to work out what password goes with it.
Any help greatly appreciated, getting a bit stressed here :(
Hi Toby,
Router#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Router(config)#no username srini
as well as
Password Recovery Procedure for the Cisco 806:
Hope this helps,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
In article ,
writes
Ta muchly :)
