Cisco 575 and 2950 LRE troubles
Sep 12, 2005 3 Replies
Jump to replies (3)
I have some apartments blocks, with about 1km of cooper cable (26 pairs, section 0.6mm2, and shielded...but I think that this shield is not connected to anyplace).
I decided install Cisco 2950 LRE (IOS 12.1(22)EA1), and Cisco 575 for clients, without use voice port, because we use ToIP, and then without splitters, only for data transfer.
I have four 2950LRE, and I cant connect more than one port for each switch. I tried all sequences, now is global LRE-SEC-COMPLETE-REACH for "scan" all profiles.
I have seen some parameters, for connected and no connected ports, but I dont understand how is possible to have an SNR 37, and in the adjacent apartment SNR 0.. ( ground power ?, third pairs cable in the wall to CPE port - I am using 2 pairs cable?, insufficient power for all ports from switch ?...
Thanks in advance,
------------------ show controllers lre status link ------------------
Port Link SNR RS Errs CPE-Tx Sw-AGC-Gain Interleaver PMD-S (dB) (dBm/Hz) (dB) Rx-Bsz Tx-Bsz
----- Lo0/1 DOWN 0 0 NA 26.8 0 0 0x04 Lo0/2 DOWN 0 0 NA 40.2 0 0 0x04 Lo0/3 UP 37 0 - 70.8 24.2 16 16 0x04 Lo0/4 DOWN 0 34384 NA 56.2 0 0 0x84 Lo0/5 DOWN 0 0 NA 57.5 0 0 0x04 Lo0/6 DOWN 0 0 NA 56.2 0 0 0x04 Lo0/7 DOWN 0 0 NA 62.2 0 0 0x04 Lo0/8 DOWN 0 4093 NA 58.3 0 0 0x04 Lo0/9 DOWN 0 0 NA 60.2 0 0 0x04 Lo0/10 DOWN 0 0 NA 56.7 9 0 0x84 Lo0/11 DOWN 0 0 NA 60.2 0 0 0x04
In article , Carlos Estrela wrote: :I have some apartments blocks, with about 1km of cooper cable (26 :pairs, section 0.6mm2, and shielded...but I think that this shield is :not connected to anyplace).
:I decided install Cisco 2950 LRE (IOS 12.1(22)EA1), and Cisco 575 for :clients, without use voice port, because we use ToIP, and then without :splitters, only for data transfer.
That sounds more like an 857 or 877 than 575. There isn't any
575 model, the 5xx series are PIX firewalls. The 857 and 877 would be IOS routers with ADSL interfaces.
Models Cisco 585 LRE CPE Device Cisco 576 LRE CPE Device Cisco 575 LRE CPE Device
In article , Carlos Estrela wrote: :Models :Cisco 585 LRE CPE Device :Cisco 576 LRE CPE Device :Cisco 575 LRE CPE Device
Dang -- every time you turn around, Cisco has put out another model line ;-)
