Hard Problem with cisco 827 router
Aug 25, 2005 2 Replies
Hello I just tried to find some topic that will solve my problem but found nothing. So let me explain: I didn't have the pass of the router so I tried to do a recovery pass as in cisco web said. I did some thing wrong, when I typed to change routers register mode I wrote 0x3___ instead of 0x2142, since then hyperterminal doesn´t show anything and I don´t find a way to contact with the router.
Any good Ideas ?
Thanks
Bit 11/12 of the configuration register specifies the console speed. With 0x3yyy, bit 12 is turned on therefore the speed change. I do not have the speed table here but on my routers which I often set to
115200, the register is 0x3922. I think you have to try diffetrent speeds of your terminal. Try it first with 115200, if it does not work then try 57600, 38400 and so on.
HTH,
Thanks lots it worked with lower speeds Really really thank you
