OSPF and EIGRP interaction troubles
Aug 25, 2005 4 Replies
Jump to replies (4)
OSPF and EIGRP interaction troubles open original image
hi there, well, I have basically the following:
A B
-------------------------- Net 1 { | } | { | } |
-------------------------- Net 2 C D
A, B, C, D are cisco routers, mix of != type.
{ } represent a slow backup link,
| | represent a fast link
A, B are configured using EIGRP C, D are configured using OSPF (differents clients) sometimes the fast link drop, and the backup take place. OK when the fast link come back, the C router get blindly routing throught A to reatch Net1, I have to manually set it back to the default D-B link.(shut down of A side interface) I don't know why routes doesn't come back to normal after link restore. I think this is because of bad interaction of protocols. or may be a too selective neighborhood ? May I have your points of view.
thanks for your time.
If A and B are running EIGRP and C and D are running OSPF, how are A and B learning the OSPF routes and vice versa? One set of those routers needs to be redistributing routes. I would probably run OSPF on the EIGPR routers and redistribute the OSPF routes into EIGRP there. HTH.
Robert
thank for the advice, I 'll check for redistribute. BTW, is redistribute working like neighborhood ?
bye
redistribute ospf 1 1000 100 250 1 1500
That tells EIGRP to accept the routes that are learned via OSPF and give them the EIGRP specific metric 1000 100 250 1 250.
HTH Robert
With redistribution you will NEED to ensure that you do not get routing loops by configuring restrictions on the redistribution. Check the documentation.
Since you have two parallel redistribution points you need route maps and or access-list on the redustribution.
