2501 won't boot
Aug 25, 2005 3 Replies
Jump to replies (3)
Hi John,
You may wish to investigate "Boot Issue Solutions" at the Cisco Router TAC Case Collection / Knowledge Base:
http://129.41.16.73/core/home Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA/Canada Toll Free: 877-549-2680 International: 828-277-7272 United Kingdom: 44-20-70784294
Hi John,
Hi John,
You may find "Boot Issues" of the Cisco Router TAC Case Collection / Knowledge Base helpful:
I recently was given an old 2501 router. I hooked up a console cable and powered it up, and it seemed to go through it's sequence, indicating memory, IOS version etc, showed a couple of error messages (e.g. CDP not enabled, etc.) and then the "hit return to continue". However, at this point it's simply frozen. I tried repowering several times and basically got the same result. Also tried sending a cntl-break during power up, and it did dump me into a ">" prompt, but then freezes.
Is this one simply destined for the scrap heap, or is there something else I can try?
thanks, john
