Gathering chassis ID through SNMP for 837.
Sep 09, 2005 5 Replies
Jump to replies (5)
Gathering chassis ID through SNMP for 837. open original image
Hi all,
I found that .1.3.6.1.4.1.9.3.6.3 is the MIB for chassis-ID of Cisco's routers. It seems not to work. Is the MIB correct?
Alex.
Hi Alex,
snmp-server chassis-id
To provide a message line identifying the Simple Network Management Protocol (SNMP) server serial number, use the snmp-server chassis-id command in global configuration mode. To restore the default value, if any, use the no form of this command.
snmp-server chassis-id text
no snmp-server chassis-id
Syntax Description
text - Message you want to enter to identify the chassis serial number.
Defaults
On hardware platforms where the serial number can be machine read, the default is the serial number. For example, a Cisco 7000 router has a default chassis-id value of its serial number.
Command Modes Global configuration
Command History Release Modification
10.0 - This command was introduced.
Usage Guidelines
The Cisco MIB provides a chassis MIB variable that enables the SNMP manager to gather data on system card descriptions, chassis type, chassis hardware version, chassis ID string, software version of ROM monitor, software version of system image in ROM, bytes of processor RAM installed, bytes of NVRAM installed, bytes of NVRAM in use, current configuration register setting, and the value of the configuration register at the next reload. The following installed card information is provided: type of card, serial number, hardware version, software version, and chassis slot number.
The chassis ID message can be seen with the show snmp command.
Examples
In the following example, the chassis serial number specified is
1234456:
Router(config)# snmp-server chassis-id 1234456
Related Commands Command Description show snmp - Checks the status of SNMP communications.
Product Name: Cisco 837 ADSL Broadband Router
Serial Number Format: 11 characters (xxxnnnnxxxx)
Serial Number Location: Chassis Input/Output (I/O) side, right edge
Cisco Product Identification Tool:
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
Cisco Unique Device Identifier Retrieval:
Brad Reese
Hi BradReese,
I only wanted to know whether the MIB I knew was correct or know. I searched for MIB about chassid-ID but on Cisco's site I couldn't download *.my file about chassis-ID. and moreover I got this message from NetSNMP when I tried to gather information on that MIB
C:\\>snmpget -c campagnolo -v 1 10.132.130.254 .1.3.6.1.4.1.9.3.6.3 Error in packet Reason: (noSuchName) There is no such variable name in this MIB. Failed object: SNMPv2-SMI::enterprises.9.3.6.3
Alex
This is a simple object, so you should attach a .0 to it (or use snmpwalk):
$ snmpwalk c4500 .1.3.6.1.4.1.9.3.6.3 SNMPv2-SMI::enterprises.9.3.6.3.0 = STRING: "FOX0637S0BU"
/Niels
Great! My start on SNMP's field is better now ;) Thanks, Alex.
