I need to know the OID of the used memory in Cisco routers & is it the same for all types of Cisco routers? Also how can I know the size of memory installed in he router?
Cisco memory?
Mar 24, 2005
You may wish to investigate the Refurbished Cisco Product Guide: well as Cisco Router Memory Table Sheets: Brad Reese Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558=20 Website:
Read the full replyYou may wish to investigate the Refurbished Cisco Product Guide:
as well as Cisco Router Memory Table Sheets:
Sincerely,
Brad Reese BradReese.Com=AE Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558=20 Website:
"Mr T" schrieb im Newsbeitrag news: snipped-for-privacy@o13g2000cwo.googlegroups.com... |I need to know the OID of the used memory in Cisco routers & is it the | same for all types of Cisco routers?
just look at
are a lot of templates. Just look at the "TARGET" Line...
With "show version" ore do you mean the OID?
Regards
Carsten Remien
Yes I mean the memory. for example, what is memory of that Cisco:
cisco RSP4+ (R5000) processor with 262144K/2072K bytes of memory. R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache Last reset from power-on G.703/E1 software, Version 1.0. G.703/JT2 software, Version 1.0. Channelized E1, Version 1.0. X.25 software, Version 3.0.0. Chassis Interface.
1 GEIP controller (1 GigabitEthernet). 1 VIP2 R5K controller (1 Serial). 3 VIP4-50 RM5271 controllers (4 FastEthernet)(4 Serial)(2 POS). 4 FastEthernet/IEEE 802.3 interface(s) 1 GigabitEthernet/IEEE 802.3 interface(s) 5 Serial network interface(s) 2 Packet over SONET network interface(s) 123K bytes of non-volatile configuration memory.20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).Slave in slot 7 is running Cisco Internetwork Operating System Software IOS (tm) RSP Software (RSP-DW-M), Version 12.0(25)S2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2) TAC Support:
(c) 1986-2003 by cisco Systems, Inc. Compiled Fri 10-Oct-03 15:23 by nmasa Slave: Loaded from system Slave: cisco RSP4+ (R5000) processor with 262144K bytes of memory.
I'm using this 1.3.6.1.4.1.9.9.48.1.1.1.5.2 to poll used memory butin some routers I get a result & in some I get nothing.
