Which type of cabling do I use to connect to a 2811 from a T1 CPE, Crossover or straight? Thanks!
Cross over cable or straight to connect to 2811 from T1?
Nov 22, 2006
Most relevant reply
T1 CPE???? What sort of T1 CPE? Smartjack/NIU or something else? Typically, I'd use the *2811* as the T1 CPE. You'd want a straight-thru to go from a Smartjack into a T1 port on a 2811. If you instead have another T1 router there, to connect two routers together on their…
If you instead have another T1 router there, to connect two routers together on their ethernet ports, use a cross-over cable.
Make sure that the cable you are using has all four pairs. Ethernet uses the green and orange pairs, but a T1 uses the blue and orange pairs.
Scott
messagenews:4564e802$0$41762$ snipped-for-privacy@auth.newsreader.octanews.com...>
smith snipped-for-privacy@hotmail.com writes:
To be more specific:
Ethernet uses pins 1-2-3-6 on an RJ45 plug
T1 uses pins 1-2-4-5 on an RJ45 plug
