Cisco wifi AP with packet filters
Oct 04, 2006 0 Replies
Hi All
I have the usual kind of home LAN with ethernet & wifi.
I need to set up a wifi AP, for somebody whose laptop is perpetually infected with trojans etc, such that he can't infect the rest of the LAN.
Basically I am after an AP which can be set up to pass only packets on port 80, 443, and whatever is required for DHCP to work (not sure what those are).
The base IP is 192.168.1.xxx and presumably the AP itself could be set up to be accessible (with a password) on say 192.168.1.240 or whatever (192.168.1.1 etc are taken)
I could be generous and allow POP and SMTP also :)
For security, plain old 64-bit WEP would be fine.
Other than the above, the AP needs to be totally dumb, passing everything through.
I think the Cisco 1100 and 1200 models can do that but I would like something with a simple browser config. Years ago I used an 803 router and could never fully understand the IOS config and all the commands...
There may be some Linksys product that can do this.
