I just got a Cisco 2821. I am currently using both of the integrated gigabit interfaces for routing (one local LAN with NAT, the other is an external subnet).
I was wondering if it is possible to configure the wifi interface (HWIC-AP) to connect to the local lan. If i do so, would i need to clear the ip settings on the local lan gigabit interface, create a bridge bvi1 and then set the ip settings in the bvi1 interface? Then would it work for NAT as well?
I have never done this before, just wondered if that is how it is done. Does anyone have any example configs for these type of routers?
Thanks, Jack
And still the small "leakage" continues because of the local control sense...
B
bod43
That's it exactly. If you don't need the wireless on the same subnet then you can just put an IP address on the wireless interface.
I don't have an example to hand, sorry. The config is identical (other then interface ID numbers) for all cisco routers and there will be plenty of example 877 configs around I would think. There was an 877 discussion here a few days ago.
J
JF Mezei
871W actually .... (I was the guilty party).
Here is a summary:
(my intranet vlan is 10 , and this uses very basic authentication, not even sure if I have encryption enabled or not :-)
36.0 48.0 54.0 station-role root antenna receive diversity antenna transmit diversity world-mode dot11d country CA both ! interface Dot11Radio0.10 description MySSID_WiFi on VLAN 10 encapsulation dot1Q 10 bridge-group 10 bridge-group 10 subscriber-loop-control bridge-group 10 spanning-disabled bridge-group 10 block-unknown-source no bridge-group 10 source-learning no bridge-group 10 unicast-flooding ! ! ! interface Vlan10 description Intranet no ip address bridge-group 10 bridge-group 10 spanning-disabled !
Now that I have a simplified config that I know works, I can start to experiment with more elaborate configs (enabling radiusj server for proper authentication etc).
J
Jack
Excellent, thanks, I will give it a try...
Report Content
ASAP.
