cisco logging
Jun 14, 2007 5 Replies
Most relevant reply
jseemann
If you're just parsing for deny messages "on the fly", you can use #>show log | include deny that will parse the log and just spit you out the deny statements. You'll also want to increase your logging buffer if you don't want to use a syslog server; typically its quite small…
Greetings,
I'm trying to accomplish something simple but having problems due to limited experience. I want to troubleshoot an access list I applied on an interface. I went ahead and added "log" to each access list and also added a deny all at the end of the list with a "log: as well. Now by enabling logging and loggin console I am able to ocassionally see my attemps from another session on the terminal. My first question is, why am I not able to see all the attemps i'm making? Also by tying this command "show logging" I get the following: My last question is, How can I view the stored console logs?
Any information would be greatly appreciated.
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited,
0 flushes, 0 overruns) Console logging: level debugging, 121 messages logged Monitor logging: level debugging, 19 messages logged Logging to: vty6(17) Buffer logging: disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 125 message lines logged
First thing is to setup a syslog server. Google Kiwi Syslog for Windows systems, in *NIX it has its own syslog server. Also what equipment is this?
Once you have the Syslog installed and running login to the device and enter:
# logging on # logging trap 7 (this will log all events on the device) # logging x.x.x.x (where x.x.x.x is the IP of the syslog server) # write memory
Once you do this all log messages will be sent to the server and stored into a logfile for later review.
Thanks for the quick reply. The reason why I didn't go the syslog way is because I want the ability to troubleshoot these acces lists on the "fly". I don't want to have to setup a syslog every time I need to troubleshoot a remote router. I would like to be able to vew the stored logs to better understand and see what's I've missed. Regarding the syslog, is there a way or a number that would only log these "%SEC-6-IPACCESSLOGP"
*Mar 1 18:15:19.667: %SEC-6-IPACCESSLOGP: list 101 denied tcp *Mar 1 18:15:19.671: %SEC-6-IPACCESSLOGP: list 101 denied tcp *Mar 1 18:16:19.687: %SEC-6-IPACCESSLOGP: list 101 permitted tcp *Mar 1 18:16:19.691: %SEC-6-IPACCESSLOGP: list 101 permitted tcp *Mar 1 18:18:19.723: %SEC-6-IPACCESSLOGDP: list 101 permitted icmp *Mar 1 18:20:19.759: %SEC-6-IPACCESSLOGP: list 101 denied tcp *Mar 1 18:21:19.779: %SEC-6-IPACCESSLOGP: list 101 permitted tcp
Thanks again.
This particular router is a 1721.
If you setup a syslog server and then setup logging on all your devices you'll never have to configure logging again. The most you'll have to do is change the logging levels (although I tend to log everything and purge old logs so I dont even ened to do that). You can do on-the-fly logging via a *nix system by using the "tail -f" command.
Cheers Scotty C
thanks. How about just viewing what the cisco router has stored?
You'll also want to increase your logging buffer if you don't want to use a syslog server; typically its quite small to begin with and depending on activity the log will scroll too fast.
(config)#>logging buffer 20000 (for example)
