cisco 2621 problem
Feb 26, 2006 20 Replies
Jump to replies (20)
cisco 2621 problem open original image
Hello all,
Somebody has given me a broken 2621 to look at. The router boots ok, but it does not show any of the interfaces. It has
2 fa's and 1 serial (WIC1T).
I put a new IOS on it, still no interfaces are showing.
Any suggestions?
Thx in advance
Dmc
config the following if it i snot already
conf t logging buffer 10000 debug exit wri mem
Re boot router and post the output for the following commands:
term len 0 show version show diag sh log
hi, thanks for swift response, here is the info... ###### Router#sh ver Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2002 by cisco Systems, Inc. Compiled Sat 02-Feb-02 03:36 by kellythw Image text-base: 0x80008088, data-base: 0x80989870
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Router uptime is 0 minutes System returned to ROM by reload System image file is "flash:c2600-i-mz.122-5d.bin"
cisco 2600 (MPC860) processor (revision 0x100) with 94208K/4096K bytes of memory . Processor board ID JAE07470EHW (3515829974) M860 processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0.
32K bytes of non-volatile configuration memory.
Configuration register is 0x2102 ###### Router#show diag
Router#sh log Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns) Console logging: level debugging, 2 messages logged Monitor logging: level debugging, 0 messages logged Buffer logging: level debugging, 4 messages logged Logging Exception size (4096 bytes) Trap logging: level informational, 11 message lines logged
Log Buffer (10000 bytes):
00:00:03: %LINK-4-NOMAC: A random default MAC address of 0000.0c83.4ed6 has been chosen. Ensure that this address is unique, or specify MAC addresses for commands (such as 'novell routing') that allow the use of this address as a default. 00:00:04: %SYS-5-CONFIG_I: Configured from memory by console 00:00:07: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2002 by cisco Systems, Inc. Compiled Sat 02-Feb-02 03:36 by kellythw 00:00:07: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start #######
If there are any WIC cards are network modules in the router, remove them then reboot and try the above show commands again.
Post results
There was 1 serial WIC1T, its now removed, here is the info:
############# Router#sh ver Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2002 by cisco Systems, Inc. Compiled Sat 02-Feb-02 03:36 by kellythw Image text-base: 0x80008088, data-base: 0x80989870
Router uptime is 2 minutes System returned to ROM by power-on System image file is "flash:c2600-i-mz.122-5d.bin"
############### Router#sh diag
00:00:03: %LINK-4-NOMAC: A random default MAC address of 0000.0c83.4ed6 has been chosen. Ensure that this address is unique, or specify MAC addresses for commands (such as 'novell routing') that allow the use of this address as a default. 00:00:04: %SYS-5-CONFIG_I: Configured from memory by console 00:00:07: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2002 by cisco Systems, Inc. Compiled Sat 02-Feb-02 03:36 by kellythw 00:00:07: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold star t Router#sh int Router#sh interfaces
Router#
Reboot into ROMMON mode (Ctrl-C) and enabling diagnostics
Capture the console output to see if any info is provided
rommon 2 > confreg
Configuration Summary enabled are: diagnostic mode load rom after netboot fails break/abort has effect console baud: 9600
do you wish to change the configuration? y/n [n]: y
Ok, tried that, here is output: ### reset
System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1) Copyright (c) 2002 by cisco Systems, Inc.
Testing lower main memory - data equals address Testing lower main memory - checkerboard Testing lower main memory - inverse checkerboard Clearing lower 4K memory for cache initialization Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Enabling instruction cache
Reading cookie
Initializing main memory
Sizing NVRAM
Initializing PCI subsystem
Exiting init
C2600 platform with 98304 Kbytes of main memory
rommon 1 >
I believe all of the interfaces are outboard of the host PCI bridge on a 2621 - so it could be the PCI bridge or the PCI bus that is defective
see Cisco doc:
Are you a hardware technician?
If the PCI bus or the bridge is indeed at fault, confirmation and/or more clues could be obtained by using the "show pci hardware" and "show c2600" commands.
Cisco da Gama
Hi all,
Here is some more output... ###### Router#sh pci hardware XILINX Host-PCI Bridge Registers device/vendor ID = 0x401310EE status/command = 0x040001C6 PCI Slave Base Reg 0 = 0x00000000 PCI Slave Base Reg 1 = 0x00000000
####### resRouter#sh c2600 C2600 Platform Information:01 = [ EC000000 ]000BFC4 Interrupts: Level
Assigned Handlers... memsize
Vect Handler # of Ints Name
ncomp_size 00 803F79C8 00000000 Xilinx bridge error interrupt :
0x004FD515 comp_ch 01 803B7664 0002186B MPC860 TIMER INTERRUPT uncomp_checksum : 0x9A916685 02 803EC758 000002F9 16552 Con/Aux Interrupt############################################ 04 803F645C 00000000 PA Network Management Int Handler ####################################################### 05 803E9BF0 00000000 Timebase Reference Interrupt
########### 06 803F64AC 00000000 PA Network IO Int Handler#############
Level 06 = [ C0000000 ] Level 07 = [ 00000000 ]
SIU_IRQ_MASK = FFFFFFFF SIEN = EF00xxxx Current Level = 00 Spurious IRQs = 00000000 SIPEND = 0000xxxx
Interrupt Throttling: Throttle Count = 00000000 Timer Count = 00000000 Netint usec = 00000000 Netint Mask usec = 000003E8 Active = 0 Configured = 0 Longest IRQ = 00000000
IDMA Status: Requests = 00000000 Drops = 00000000 Complete = 00000000 Post Coalesce Frames = 00000000 Giant = 00000000 Available Blocks = 256/256
PLD Status: PLD version information not available.
Router#
Here is the output from this command from a functioning 2600 -
router# show pci hardware
XILINX Host-PCI Bridge Registers: Vendor / Device ID: 0x401310EE Status / Command: 0x040001C6 PCI Slave Base Reg 0: 0x00000000 PCI Slave Base Reg 1: 0x04000000
correctly programmed. It is possible that some error on the PCI bus caused IOS to not even initialize the base registers or the PCI subsystem at all. The vendor/device id seems correct, however. What seems surprising is that IOS was not more verbose about the errors it seemingly ran into at init time. I would expected have some error messages about any PCI issues.
Another thing in the init-time error messages you posted earlier is the message about using a random default MAC address. That error usually happens if the read-only device that has the base MAC address of the device is not being read correctly. It will be a EEPROM or a PLD or something like that. Perhaps that error is also somehow causing an init of the PCI subsystem to be skipped completely.
The "show c2600" indicates that there were no error interrupts and so that seems ok.
Cisco da Gama
PLD info not being available is another indication of the problem
show c2600 from one of my lab routers shows the following:
PLD Status: Version string burned in chip: "B829052698" New version after next program operation: "B829052698" PLD family type: "2096" PLD chip ID: 0x0013 Device is programmable
Since the router is hosed at this point, it probably will not hurt to try to execute the
upgrade pld command
see
NOTE: The WIC must be removed priro to executing this procedure
Hi, tried the upgrade pld command, got response:
No upgrade is required
What to you see when displaying ROMMON cookie?
rommon 1 > priv
Password:0000
rommon 2 > cookie
cookie:
01 01 00 b0 64 4c e5 40 43 20 00 ff 00 91 00 20 00 00 00 00 00 00 00 00 4a 41 44 03 50 30 47 41 34 02 03 00 00 00 00 00 00 ff ff ff 58 06 49 0b 17 0d ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Lol, no i aint given up on it yet Merv.
Here is the output from cookie:
#### rommon 2 > cookie
cookie:
01 01 00 0e 83 a1 46 e0 43 20 01 ff 03 6d 00 20 00 00 00 00 00 00 00 00 4a 41 45 07 47 30 45 48 57 01 00 00 00 00 00 00 00 ff ff ff 68 06 49 1e 4a 02 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
That cookie looks good.
The base MAC address of your router is 00-0e-83-a1-46-e0
The process board id is 4a 41 45 07 47 30 45 48 57
JAE07470EHW
Have you physically inspected the motherboard to see if there are any burn or arc marks ?
Merv, Any chance could you explain the cookie thing a bit further? I will check the internals next.
David
