Boot ROM chip required to upgrade both a Cisco 2610 and a Cisco 2620 router to support 32 megs+ flash and more than 64 megs RAM
Jun 14, 2007 1 Replies
Hi, all
Could anyone tell me what I need to order, and the best place to order the boot ROM chips required to upgrade a Cisco 2610 and a Cisco 2620 router to XM functionality? I'm using 1 of each in my lab, but don't know what is the latest revision of the boot rom, nor the best place to purchase it
Thanks!
You need to order the part cisco2620xm.
eBay should have a bunch.
There is no way to update the boot ROM to get past the memory controller limitations on the ancient boxes.
The only boot ROM upgrade available is on existing XM boxes to take the limit from 128M up to 256M of DRAM on the 26??XM boxes, but you have to already have the XM router model in the first place.
You're stuck with the older non XM boxes, you can only get a new router.
