CISCO 2950 vlan config problem
Aug 18, 2005 4 Replies
Jump to replies (4)
I have a 48 port cisco 2950 switch and I need kinds of configuration:
1) port #48 is connected to a smartbits traffic generator
2) 10 other ports need to receive this traffic
config I tried was ...
int fastethernet 0/1 switchport access vlan 11 . .. . int fastethernet 0/10 switchport access vlan 11
int fastethernet 0/48 switchport mode trunk
This doesn't seem to work. Ports 1 -10 are not receiving the traffic!
The second config that I need is...
1) port #46 is connected to a smartbits traffic generator
2) 5 other ports, each on a different vlan should recive the traffic from port #46
Appreciate your help. Thanks.
If you didn't change the vlan on port 0/48 the default is vlan 1, so how or why would the ports that are on different vlans SEE the traffic generator thats on vlan 1..
Same here (I think)
I need something like the foll. for the second config:
1) vlan 11 : member ports 12, 46 2) vlan 12 : member ports 13, 46 3) vlan 13 : member ports 14, 46 4) vlan 14 : member ports 15, 46 5) vlan 15 : member ports 16, 46
I would like a sample config for the above.
Thanks
I don't know that you can do that. The whole idea of vlans is to make/keep the ports on different lans in the switch. So how/or why would you have port 46 in all your different vlans???
On 19.08.2005 11:11 snipped-for-privacy@excite.com wrote
try something like
vlan11 vlan12 vlan13 vlan14 vlan15 ! interface FastEthernet0/12 switchport access vlan 11 switchport mode access ! interface FastEthernet0/13 switchport access vlan 12 switchport mode access ! interface FastEthernet0/14 switchport access vlan 13 switchport mode access ! interface FastEthernet0/15 switchport access vlan 14 switchport mode access ! interface FastEthernet0/16 switchport access vlan 15 switchport mode access ! interface FastEthernet0/46 switchport trunk encapsulation dot1q switchport trunk allowed vlan 11-15 switchport mode trunk !
Arnold
