question of vlan cisco
Mar 03, 2007 4 Replies
Jump to replies (4)
question of vlan cisco open original image
hi pleas help me my switch 2950 dose not work good
in show vlan i see on defult vlan (vlan 1) int gig 0/1 in this vlan ports therefor i think it send broadcast too all port and terafik is very bad i want too do " no switchport mode access" until int gig 0/1 dose not work in vlan 1
it work in trunk mode pleas help me
hadi skrev:
dont use the default vlan1. Always change it to something else...
Best Regards Martin
There is no reason you can't use VLAN 1, but Cisco suggests avoiding it. I do not think this is your problem, but I can't understand what you are asking or what your problem is, so I can't know for sure. Here is a link to the vlan 1 stuff from cisco.com:
If you are not running Vlan's leaving it default is ok. If you want to vlan your traffic it is best to use a completely different vlan. All interfaces on the switch are configured as vlan1 by default. Maky your life alot simpler and set up a new vlan as the other user suggested and apply that vlan to the interfaces you want segmented.
