How do I vlan my already subnetted address?
Apr 24, 2005 8 Replies
Arnold Nipper
On 24.04.2005 13:51 Marshall Lymer wrote If there is no need for both Vlans to talk to each other, simply make two Vlans and put each port into the correspondant vlan. Done! As you didn't tell us what switches you are using (CatOS or IOS) I can't give you any implementation…
How do I vlan my already subnetted address? open original image
I have an already subnetted group of addresses, 154.225.66.176 / 28 to be exact. That's 14 addresses to work with and I can't obtain more. Now I am realizing that I want to isolate traffic and split it so that one group doesn't see the traffic of the other group. I don't need to route traffic between the two new vlans. I want to stick only a few of machines on one vlan and the rest on another. How do I do this and program this on my cisco switch? Please keep in mind I can't obtain another pool of ip addresses, this is all I have to work with. Here's my current device / ip address list:
154.225.66.177=router
154.225.66.178=switch
154.225.66.179=pc 1
154.225.66.180=pc 2
154.225.66.181=printer
154.225.66.182=printer
154.225.66.183=printer
154.225.66.184=pc 3
154.225.66.185=access point
154.225.66.186=pc 4
154.225.66.187=pc 5
154.225.66.188=pc 6
154.225.66.189=pc 7
154.225.66.190=pc 8
vlan1 will include (177 to 185) and vlan2 will include (186 to 190).
Thanks!
As you didn't tell us what switches you are using (CatOS or IOS) I can't give you any implementation advice.
Arnold
On 24.04.2005 17:09 Marshall Lymer wrote
! ! VLAN 10, ports .177 to .185 ! interface range FastEthernet 0/1 - 9 switchport access vlan 10 ... ! ! ! VLAN 11, ports IP .186 to .190 ! interface range FastEthernet 0/10 - 14 switchport access vlan 11 ... !
Note that PCs in VLAN 11 don't have access to the router as this router is in VLAN10.
Arnold
Thanks. That was easy enough. Now since you say that the router is in VLAN
10, the PCs in VLAN 11 obviously won't have access to the router. I don't want to implement interVLAN routing, but there must be a way to make the port that has the router attached to the switch (on ours its fa0/24) part of both VLANS so that the PCs in VLAN 11 will be able to get to the router.
Thanks again! You've been helpful.
On 24.04.2005 18:42 Marshall Lymer wrote
Make the router port a trunk port, and configure subinterfaces on the router. But be aware that the IP config then looks very ugly.
Arnold btw: Your email adress bounces ...
: host sdsu.edu[130.191.229.14] said: 550 5.1.1 ... User unknown (in reply to RCPT TO command)
Arnold,
Assuming that this config used sub-interfaces on the same router, wouldn't another IP address be required for the 2nd sub-interface.
I have never seen a config where 2 x sub-interfaces were part of the same network range. Would this be valid - just wanted to clarify to help my understanding.
Regards
Darren
On 24.04.2005 20:39 Darren Green wrote
usually that would be the way you do it.
No, you (still) can't do that. But maybe you can
  • leave the 2nd sub-interface un-numbered
  • turn on proxy-arp
  • route each PC's address to the 2nd sub statically
as said, very ugly, but it might work,
Arnold
You might also want to look into the Private VLAN feature
Arnold
