cisco 837, static ip's, and routing.
Aug 19, 2005 4 Replies
Jump to replies (4)
I don't have any experience with the 837 series, but from a routing perspective I would say you are OK. As long as you have a static route to your provider and they are advertising your block to the Internet (which they must be doing since you can surf), you should be OK. One question I have though is about the dialer interface. Have you already established the Internet connection with your PC when you are trying to access it? If not, traffic from the Internet is probably not going to bring up the interface. Just a thought. HTH.
Robert
Hey guys,
Can someone help me with a quick cisco 837 problem i'm having with my 837?
My isp has given me an 8 ip block. For arguments sake we say this is the :
80.229.1.8 network. (real ip's not shown for security)
I've assigned 80.229.1.9 to the 837 router and ethernet port using the the 'ip unnumbered' command to allow the dialer interface to "borrow" the IP address of the ethernet already configured on the router.
I've got my PC on the network with the IP: 80.229.1.10, however, whilst I can surf the net, I cannot access the PC from across the internet.
I guess I may be required to implement an access list, or add some static routes to the router?
Can someone please advise me.
I've pasted my configuration below:
Any help appreciated, thanks in advance.
! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! boot-start-marker boot-end-marker ! no logging buffered enable password topsecret ! no aaa new-model ip subnet-zero ! ! ip ips po max-events 100 no ftp-server write-enable ! interface Ethernet0 ip address 80.229.1.9 255.255.255.248 no ip mroute-cache hold-queue 100 out ! interface ATM0 no ip address no ip mroute-cache atm vc-per-vp 64 no atm ilmi-keepalive dsl operating-mode auto hold-queue 224 in pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface FastEthernet1 no ip address duplex auto speed auto ! interface FastEthernet2 no ip address duplex auto speed auto ! interface FastEthernet3 no ip address duplex auto speed auto ! interface FastEthernet4 no ip address duplex auto speed auto ! interface Dialer1 ip unnumbered Ethernet0 ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication chap pap callin ppp chap hostname snipped-for-privacy@isp.net ppp chap password 0 plaintextpassword ppp ipcp dns request ppp ipcp wins request no routing dynamic hold-queue 224 in ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ip http server no ip http secure-server !
dialer-list 1 protocol ip permit ! control-plane ! line con 0 exec-timeout 120 0 no modem enable transport preferred all transport output all stopbits 1 line aux 0 transport preferred all transport output none line vty 0 4 exec-timeout 120 0 password topsecret login transport preferred all transport input all transport output all ! scheduler max-task-time 5000 end
I'm posting from another account, however can I say that the problem remains as was, and that is that I am unable to connect to anything past the router, i.e. my PC which has a real IP address. The PC has full internet connectivity!
The config looks okay and must be if you can access the internet from the PC behind the router. I doubt that the problem lies with the router and is more likely to be the PC behind it. I preume that you are running a firewall of some kind? How are you trying to access the PC? What services?
Chris.
My apologies Rob and Chris.
Thanks for verifying my configuration! I booted into linux instead, and it was pingable from the net - and after investigating what could be causing the problem, I finally diagnosed my 'Cisco VPN client' as the problem... it's stateful firewall was on!.
ps. for those who don't know, the cisco vpn client is a piece of software used to connected to a vpn server/router - you don't need any hardware locally for this to work.
Cheers guys :)
