Example of Layer 2 VLAN
Mar 06, 2008 3 Replies
Jump to replies (3)
Example of Layer 2 VLAN open original image
Hi folks,
I'm trying to configure a catalyst 3650 and need some help. I've got two vlans that I don't want to propagate or broadcast to other switches, so I need to configure layer 2 vlans. Can someone send me an example of how to do this?
Thanks, Chris
Just don't configure a layer-3 interface, or leave the layer-3 interface shutdown..
vlan 10,20 int FastEthernet 0/1 switchport access vlan 10 int FastEthernet 0/2 switchport access vlan 10 int FastEthernet 0/3 switchport access vlan 20 int FastEthernet 0/4 switchport access vlan 20 no int Vlan 10 no int Vlan 20
Ah! It IS that simple....Thanks, Doug.
If you have multiple switches in a network and need certain vlans contained to a group of switches, don't use VTP.
VTP would be configured in Transparent mode, and the switches local vlan database would only contain the vlans defined on that switch. This prevents other vlans from passing traffic on trunk links.
If vtp is in use, then configure vtp pruning, which prevents unwanted vlans to be propagated down the trunks.
Scott
Chris wrote:
