Cisco 2950 flash not initializing
Nov 15, 2006 3 Replies
Jump to replies (3)
Cisco 2950 flash not initializing open original image
Dear all,
when i loading the Cisco 2950 Switch,i am getting following error.
" Loading "flash:c2950-i6q412-mz.121-22.EA8a.bin"...flash:c2950-i6q412-mz.121-22.E A8a.bin: no such file or directory
Error loading "flash:c2950-i6q412-mz.121-22.EA8a.bin"
Interrupt within 5 seconds to abort boot process. "
i have tried to loaded the new ios image (.bin file) in switch through xmodem.but if i am giving the "boot command",it takes normal boot & but restarting the switch automatically.it's comes to following prompt
" Flash_init load_helper boot
switch:
kindly provide me the suggestion to recover from this issue.
Regards, Mano
Hi Mano,
You may wish to investigate:
Cisco Catalyst 2950 Series Switches Recovering Catalyst Fixed Configuration Switches from a Corrupted or Missing Image
Hope this helps.
Brad Reese
Thanks a lot...i already did as per that guide.still i have the same problem.
Manoj
Is show boot the same as dir flash: ? It should be
