Can't erase flash on a cat 2950
May 15, 2007 1 Replies
Most relevant reply
Coopig
This issue is documented in the Cisco bug ID CSCsc41813 ( registered customers only) . In order to resolve this issue, you can upgrade the switch software to the Cisco IOS release not affected by the bug.
Hi all,
I would like to upgrade a cat2950. So I start want to delete the completly flash with the command:
=========================== switch#erase flash: Erasing the flash filesystem will remove all files! Continue? [confirm] %Error erasing flash: (Device or resource busy) switch#dir flash: Directory of flash:/
2 -rwx 273 Jan 01 1970 01:01:01 env_vars 3 -rwx 556 Dec 10 2006 13:40:45 vlan.dat 4 -rwx 109 Mar 01 1993 01:01:26 info 17 -rwx 2820 Mar 21 2007 12:31:48 config.text 5 -rwx 2250767 Mar 01 1993 01:02:38 c2950-i6q4l2-mz.
121-6.EA2a.bin 6 drwx 64 May 10 2007 05:22:12 html 19 -rwx 109 Mar 01 1993 01:03:34 info.ver ===================================
Any help for me ?
greetz dennis
