Error Info Code: 3627 Copying new IOS images
Apr 18, 2006 1 Replies
Hello Have anybody known problem with upgradeing IOS on 2950 switch using ciscoworks RME? In my case i have following result: ...
Loading image file to flash device : c2950-i6k2l2q4-mz.121-22.EA6.bin -->
flash:c2950-i6k2l2q4-mz.121-22.EA6.bin Running image will be overwritten by the new image ... Error loading image to Flash. Error Info Code: '3627' Message: 'The flash CLI rename operation failed.' Action/Reason: 'Cause: The CLI command failed on the device. Either the source file is not on the Flash or the CLI has changed. ' ....
Thanks for tryin to help!
you may be affected by the following issue
You may have to perform the upgrade manually
