cisco 2900 vlans
May 27, 2006 3 Replies
Jump to replies (3)
I have a old cisco 2900 awitch. I have it set-up with 4 vlans on the switch. I'm thinking of getting the linksys wap54gp that can have up to 7 vlans. Does anyone know how to configure the port on the cicso switch to have 4 vlans on one port???
Thanks
Which old cisco 2900 switch? One model can't do what you want, a bunch can. The exact model # will determine what you have.
If you have one of the ones that can,
switchport trunk encaps dot1q switchport mode trunk
Hi Gene,
You may wish to investigate Cisco Product Guides from among the last 8 years:
Sincerely,
Brad Reese BradReese.Com - Leverage Your Cisco Network
1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
