how to flow Vlans IDs on Intel series 510T switches
Mar 23, 2006 2 Replies
brink
IIRC the Intel switches do not use 802.1Q tagging (no tagging at all in fact) so you will not be able to connect a cisco trunk to a 510 and make it work. If you have only 4 vlans use 4 links configured as access port on each side, or replace the 510 If using the 510 make sure…
Hi All
Please help me in Vlan configuration on Intel express 510T .I have Cisco3750 switch and i want Vlans to flow in Intel express 510T
I had configure 4 Vlan in cisco switch .But i am not able to apply these vlan on Intel express 510 T switches.At the same time all these vlans are working fine in cisco2950 switch.
Thanks Chetan
4 vlans use 4 links configured as access port on each side, or replace the 510 If using the 510 make sure the IP vlans defined match the IP info on the Cisco side.
Luck,
Frans
