Csisco5200 VoIP issue
May 27, 2006 2 Replies
Most relevant reply
www.BradReese.Com
Hi Sam, This issue is described in Cisco bug ID CSCdu73881. The IP phone user experiences one-way audio after a remote H.323 or Session Initiation Protocol ( SIP ) device sends the Voice over IP ( VoIP ) gateway a Hold, Transfer, or Re-invite message. Disable the voice-fastpath…
Csisco5200 VoIP issue open original image
Dear Master :
I got a problem , twos sides use cisco 5300 as below:
--------------- A User -as5300(a)- -as5300(b)- < --- E1 ---> B User -------------
B user can hare A user's voice , otherwise A user can't get B user's voice. the specification in As5300(b) as below: What's maina command can fix or find out the problem ? or upgrade firmware ?
IOS (tm) 5300 Software (C5300-IS-M), Version 12.3(10a), RELEASE SOFTWARE (fc2) Copyright (c) 1986-2004 by cisco Systems, Inc. Compiled Fri 22-Oct-04 17:48 by kellythw Image text-base: 0x60008AEC, data-base: 0x615EE000
60 DSP(s), 60 Voice resource(s)
AS53_TPE#sh vfc 1 version dspware DSPWare version in VFC slot 1 is 4.1.41 VCWare/DSPWare version compatibility OK
AS53_TPE#sh vfc 1 version vcware
Voice Feature Card in Slot 1: VCWare Version : 11.41 ROM Monitor Version: 1.2 DSPWare Version : 4.1.41 Technology : C542 VCWare/DSPWare version compatibility OK
AS53_TPE#sh vfc 1 technology Technology in VFC slot 1 is C542
AS53_TPE#sh vfc 1 board VFC board state is UP, vfc status VCWARE running(0x4) VFC board in slot 1 with 30 dsps
AS53_TPE#sh vfc 2 board VFC board state is UP, vfc status VCWARE running(0x4) VFC board in slot 2 with 30 dsps
Hi Sam,
Disable the voice-fastpath hidden global configuration command, using the syntax no voice-fastpath enable.
Note: This is a hidden command and it is enabled by default.
Also, be aware of Cisco bug ID CSCdu38797.
This bug causes one-way voice to return after the gateway is reloaded. See this bug ID listing for Cisco IOS=AE Software Releases with the bug fix integrated.
For more information on this issue, refer to -
Disable voice-fastpath on AS5350 and AS5400:
found on Cisco's Troubleshooting One Way Voice Issues:
Hope this helps.
Sincerely,
Brad Reese BradReese.Com - Cisco Compatible Resource Center
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant=20 Website:
Dear Reese :
Got your point , I 'll follow up the document.
I thank you once again for your help .
Sincerely yours,
" ???????: snipped-for-privacy@j33g2000cwa.googlegroups.com... Hi Sam,
This bug causes one-way voice to return after the gateway is reloaded. See this bug ID listing for Cisco IOS® Software Releases with the bug fix integrated.
Hope this helps.
Sincerely,
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
