cisco 1700 username and password problem
Jul 13, 2005 3 Replies
Jump to replies (3)
Hello I am trying to setup username/password on one of my routers but it behaves different from the others when i type line vty 0 4 the login local does not exists, intead i get login authentication. How do i set up login on this router? thanks.
Not sure if this is correct but if you setup a local username on the router then you should get the option under the line settings "login local".
Local usernames are setup as follows:
username myusername password mypassword
Hope this helps.
Rob
On mine I have,
username password ! aaa new-model ! aaa authentication login collossus local ! line vty 0 4 access-class 11 in logging synchronous login authentication collossus transport preferred none
Chris.
Thanks Chris, I believe the problem i had was that i had line and no local on my aaa authentication
