cisco Configuration
Aug 14, 2007 6 Replies
Jump to replies (6)
cisco Configuration open original image
Hello,
Soon, I will need to setup a t1 line between 2 sites. I have purchased 2 Cisco 1841 routers with the T1 DSU/CSU card in slot 0 (WIC 1DSU-T1 V2).
Anyway, I think I have everything working properly back to back, but I'm running into a weird problem where one side (config A) can only ping the other side 60% of the time, and the other side (config B) can not ping config A at all. Below are my configurations. Can anybody tell me what I'm doing wrong? This is going to be my first T1 deployment, and it has to work. Thanks:
Config A:
yourname#show run
Building configuration...
Current configuration : 2044 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip domain name yourdomain.com
username cisco privilege 15 secret 5 $1$uF6w$fMy7xMIp2BRaJMSi214EM/
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 10.10.0.1 255.255.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip unnumbered FastEthernet0/0
encapsulation ppp
ip classless
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege le
vel of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to
^C
line con 0
exec-timeout 0 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
end
config B:
yourname#show run
Current configuration : 2093 bytes
version 12.4
hostname yourname
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-inter
no mmi pvc
ip subnet-zero
ip cef
username p1admins privilege 15 secret 5 $1$nAL8$hheCXtA4rN6.RosXTheFz0
ip address 10.10.10.2 255.255.255.248
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
encapsulation ppp
service-module t1 clock source internal
ip classless
ip http server
control-plane
banner login ^C
vel of 15.----------
Here are the Cisco IOS commands.ce.
username privilege 15 secret 0 ture requires the one-time use of the username "cisco
no username cisco
Replace and with the username and password you want to useassword have a privilege le
^C
line con 0
exec-timeout 0 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Right now both routers are configured back to back. Thanks.
-- John
I am not 100% sure, but I believe with ip unnumbered you have to have some routing protocol running. Do you have a routing protocol configured?
No, you don't need to run a routing protocol with ip unnumbered.
Chris.
John, The problem you are having is an overlapping/mis-configured masks on the Fa0/0 interfaces. If you change the masks to something that is not over-lapping, it should work fine. Try configuring both of them with /24 masks (255.255.255.0)
As KDawg44 mentions, you WILL need a routing protocol (sorry Chris). Any routing protocol will do - even static routes. Here's what you *could* use assuming: --- router A: fa0/0 --> 10.10.0.1 /24 --- router B: fa0/0 --> 10.10.10.2 /24
Add to router A's config: ip route 10.10.10.0 255.255.255.0 s0/0/0
Add to router B's config: ip route 10.10.0.0 255.255.255.0 s0/0/0
Good luck - Have fun JC
I wouldn't class static routing as a "routing protocol" I was simply saying that ip unnumbered doesn't require a routing protocol, which it doesn't. Static routes work fine. I have installed a couple of hundred routers in this manner!!
Chris, I know we're splitting hairs here - not to mention off-topic, but as a matter of classification, I would include static routing in the same class as any other routing protocol. If static routing isn't a "routing protocol", then what is it?
I think what you mean is it's not a **dynamic** routing protocol.
Let's check the definitions of the words...
Routing:
  1. the arranging and scheduling of mail for delivery.
    Protocol:
  2. code of correct conduct; "Saftey protocols"; "academic protocol"
    Static routes - is a method used to arrange delivery by a code of correct conduct [in our case - packets].
If that doesn't convince you, Cisco lists it as one if it's Routing Protocols in it's table of administrative distances.
-JC
Thanks guys. It works now with PPP & HDLC. I'm going to keep playing with it. I'm just using a default route now going through the serial interface on both routers. It seems to work fine. However, if I switch from PPP to HDLC, it seems to take a little while before the routers can ping each other (about 30-90 seconds). Maybe I'm going crazy.
Anyway, the only problem I'm having now is that the connection seems to be slow. As you are aware, it is a back to back T1 connection. If I perform a "copy flash:myimage tftp", the image is downloaded through the connection, but it seems very slow. It takes me about 20 minutes to download the image. I'm going to check to see if there is some type of baudrate or speed command to increase this speed. If you guys have a suggestion, it would be greatly appreciated.
Thanks again for the help thus far.
-- John
